Good Afternoon, I've just upgraded my windows 7 to windows 10, and after i do that my autocad civil 3D when i try to insert a google earth image or surface from GE the program gives the following error "google earth does not appear to be started, to import the google earth view into autocad, start google earth and orient the view to the area of interest. the view within google earth should be looking straight down at the surface. ensure the google earth application window is at its maximum size. then rerun the comand" In the windows 7 the program was running straight but now with the upgrade it's not working anymore, what could be the problem? the plugin? it's not compatible? Best regards Luis Narciso
