Can't add labels to Profile View Crossings
antonioygeo
antonioygeo
Hello, I've been trying to add some crossing profiles to my profile views.
As you can see in the photo, when I create a profile crossing, i can see the Profile View Crossing Object and its marker, but I can't see its label.
Any ideas?
I'm using Civil 3d 2020.
wfberry
Hopefully, this will get you started (By Jeff Bartels)
https://www.youtube.com/watch?v=RGvJlQjZeYA
Bill
antonioygeo
Thanks for the answer.
I have done everything that Jeff Bartels says on the video, but I still can't see the label. The visibility is set on True and i still can't see it.
If no one has the same issue, I guess there is some variable hidden, or is it a known problem with Civil3d 2020? I am really confused.
antonioygeo
Any answer anyone?
wfberry
Post your drawing.
Bill
antonioygeo
Ok, thanks a lot Bill for the help.
I managed to find the problem and I will try to explain it in case someone faces the same problem.
I usually work with the templates that we have created in our company. So I created a new blank DWG and I noticed that the crossing label was visible and I figured it must be some settings that make the label not visible in our templates.
I then used displayconfig-->Drawing Defaults-->Plan-->Display Representation Control, went all over to ProfileView Crossing Objects and I made sure that it was ticked (set to visible).
Then, in the same menu, I went to Crossing Profile Label and made sure that it was also visible and that solved my problem.
I never made changes to these settings, so I guess if your templates are older than 2019, they are automatically unticked and you have to make sure they are visible.
