Can I change the color of my Active Tab?
lunarfaze
lunarfaze
Good morning.
Does anyone know if there is a way to change the color of just the active tab at the bottom (as seen in the image)?  I want to make it so it stands out more.  I looked through the OPTIONS -> DISPLAY -> COLORS (under Display File Tabs) and could not find anything.
As always, thank you!!!
Udo_Huebner
This is a general AutoCAD Question, perhaps you get more answers here.
https://forums.autodesk.com/t5/autocad/ct-p/8
But as far as I know, you cannot modify the colors for the AutoCAD color themes (dark or light)  individually.
https://knowledge.autodesk.com/support/autocad/getting-started/caas/simplecontent/content/color-them...
But the color of the tabs is not windows color scheme related.
Gruß Udo Hübner (CAD-Huebner)
Nilesh_Chaudhari
Hi @lunarfaze ,
I don't think it's possible. You can submit an Idea here.
Nilesh Chaudhari
Product Support Specialist
MMcCall402
I've seen a color theme file(s).  They end in .xbel.  You can open them with a text editor and make changes, if you know what you're doing.  The colors are defined by their hex value.  I don't know if the tab colors are in there as its not very descriptive as to what the color values are for.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
