Hello š
To do part of the project, I need to calculate the length of CUT section in CORRIDOR Surface and Length Of FILL section In EG Surface, at all sections (over 200 sec no.), i can calc unautomated
like attached Pic.
PLZ ---- HELP š
Solved by andrewofabley. Go to Solution.
Do you need the horizontal distance of the cut/fill areas? Then you can just measure with the DI command.
If you are looking for the *volume* of the cut and fill you need to create a Volume Surface with the EG as the base and the proposed surface as the comparison.
YES, I need Length, i need Automated Process, Because Section No. is so much. using DI(command) is so Time-consuming, TNX. my Clint use this length to Payment of bed preparation item, In addition to the Volume Pay Item.
I am assuming you are using Corridor model,
My suggested workflow would be to use a combination of the Civil 3D Featureline reports and MS Excel. featureline report will Export an Excel featurelines (either DaylightCut or Daylight Fill) report at the specified intervals, say 10m. In excel filter out for example the chainages that have a value for Daylight-Cut, then add up the chainage intervals to achieve your length of Cut. Do the a similar exercise for Fill.
I have created an a video (https://autode.sk/3pMkj3U) to show you how to run the report (just in case you need one). The rest is up to your MS excel expertise. The report I created in the video is also attached for your reference.
That is the workflow I thought could help
I've attached your file with what I *think* you are after - but I believe that the solution provided by @L3GO-Ed is the out-of-the box way to go.
My Calc'd Total Fill Length: 391.43 m
My Calc'd Total Cut Length: 383.04 m
(Analysis compute time: 4.4 seconds)
That's based on what's in the file I recommend you go the Excel Route - or PM me if you want the alternative solution.
HI, CAN U PLS EXPLAIN TO ME HOW U AUTOMATICALLY GOT THE LENTGH FOR EACT CUT AND FILL SECTIONS? THANKS!
