- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Our company has just recently updated to from Civil 3D 2023 to 2025. When I plot using DWG to PDF (same thing we were using in 2023) It won't plot any points from a csv file. Everything shows correctly in the print preview, but after plotting and opening the PDF, the points are gone. My work-around is to plot using Bluebeam PDF, however this is not an ideal solution as we prefer to use one of the full bleed options and that is not available in Bluebeam PDF.
I have opened the same drawing in the 2023 version and it will plot correctly. I have changed all of my settings to mirror the 2023 settings and even went to the 2025 options-files- and changed all of those options to the CD3 2023 folder to try to find the error.
If I am in 2025 and create an point manually with the same point styles, it will plot using DWG to PDF so this tells me there is some issue with only they points imported from a csv.
Is this a 2025 error that needs to be corrected or is there an setting that has been added to 2025 that is not in 2023 that I am missing?
