ever since i loaded c3d 2017 geomap has not worked right. if i log into 2016 i have to relogin to a360. then when i get back into 2017 i have to log in again. i have tried several things found in the discusion group from deleting files in the user dir, to reinstalling c3d, to running a batch file that changes registry entries. often things appear to be fixes until i get out of the dwg and get back in.
often i login to a360 and geomap shows up and then a couple seconds later it says i am logged out.
if i pull up a dwg in acad map all works well with no problems ever.
this must be some kind of civil3d registry or software setting problem i suspect.
thanks, alex
My name is Pat and I am with Autodesk Technical Support. This is most likely an A360 error. On the start tab for 2017 when you start it up, what does it say for your a360 login?
Hey @alexkonieczka
What does it say on the A360 portion on the start tab in Civil 3D each time you log in?
Feel free to respond to this with an update if the status changes.
