So the broken concrete hatch bug is back in 2017.
Yes I have changed the origin of the hatch with no luck
Yes the hatch is located not close to the origin of the drawing (long ways away)
Solved by chriscowgill7373. Go to Solution.
Are you using an OLD hatch pattern file? What fixed the issue was Autodesk carrying the decimal precision to 8 decimal places:
*AR-CONC, Random dot and stone pattern
50, 0,0, 4.12975034,-5.89789472,....
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Yes I verified I am using
AC-CONC 4.12975034 etc. Thank you for the tip tho! I will keep an eye on this
Don't suppose you can post a portion of the drawing that is showing the problem?
Warren Geissler
I mean the actual DWG file so I can look it over.
Warren Geissler
Was this drawing created a long time ago? I'm able to create NEW hatch fine and even use MATCHPROP from the old to the new fine - but darned if I can fix the old hatch.
Warren Geissler
Here's the drawing with a hatch I just added
Warren Geissler
Thanks, it is wierd. New hatch I create next to yours is fine. In fact, I can match hatch that is messed up and it shows up correctly in the new hatch. In the large drawing file I am working in...some (not all) of the hatch shows up incorrect, even the stuff I making right now.
Thx tho
Hatch patterns come with there own ORIGIN these days, if you set the origin of the hatch pattern near your location all should work just fine and as expected. The reason for the break-up in the hatch is you at a high coordinate value.
Rick Jackson
Survey CAD Technician VI
UCS <enter> WORLD <enter>
PLAN <enter> WORLD <enter>
set hatch origin, select bottom left corner, hatch gets fixed:
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Crazy bug, so basically the origin button is useless unless your in World. Crazy stuff
Ok. Here's another twist.
C3D 2017. Latest fixes and SPs.
I have a hatch base file with concrete hatching. Origin points are set close to hatch and concrete hatch looks fine.
Xref this base file into sheet file and hatching is fine.
Print the modelspace sheet file to PDF and hatching is fine.
Go to paperspace layout and hatch in viewport "looks" fine.
Print paperspace layout to PDF or paper, and hatch is broken.
Go to modelspace, hatch looks fine, go back to paperspace, and hatch is broken.
This is totally bizarre, and happening quite frequently lately.
Update:
One thing I forgot to check before posting and this fixed my issue.
DON'T use annotative hatching!
Once I changed the hatch in my base to be non-annotative, it fixed itself and worked fine.
I fixed this by switching off graphics acceleration and setting the HPANNOTATIVE variable to 1.
