I am trying to import two CSV files that I created from the soil borings. When I go into the Geotechnics tab, Import, switch the file type to CSV, I do not get the two file locations import option. The menu stays the same when switching through the three file types - AGS31, AGS4, and CSV (It only asks for the File Path). Does anybody know how to get it to switch so I can import Hole and Geology files? Currently using Civil3D 2014.
Solved by neilyj666. Go to Solution.
