Civil 3D Forum
Block won't explode and Civil 3D goes into not responding mode
4 REPLIES 4
neilyj666
264 Views, 4 Replies
I've been given a drawing (which I can't share) that has Civil objects contained in several blocks e.g. EGL and proposed. I have selected and one and hit EXPLODE and Civil 3D has been Not Responding for 10 minutes and counting. I don't know how the blocks were created and I can't think why they wouldn't explode.
I have WBLOCKED the blocks and in the resulting drawings the civil objects appeared in the Prospector tree as I'd expect so I have been able to use the information but I'm at a loss as to why the originals won't explode so any suggestions?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Labels (1)
4 REPLIES 4
neilyj666
in reply to: neilyj666
...after 30 mins of not responding I killed the process...Civil 3D seems to do the "not responding" thing a bit too often
Try exporting the Civil 3d drawing to AutoCAD and see if you get the same thing.  It is very curious, this isn't something I have run into.
With the not responding, I always look to see if memory is being exchanged.  I think of not responding as 'not accepting input'.  (I'm sure you know this.)  Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Cadguru42
Have you tried creating a new drawing and inserting a single block from the other file individually?
C3D 2022-2025
Windows 11
32GB RAM
AllenJessup
Is it possible there was a hidden message box. I've had Civil 3d appear to be frozen but found out that there was a hidden box waiting for input. Try Alt+Tab or Window Key + Tab
Allen Jessup
CAD Manager - Designer
Rail Community
