Announcements
Bing Live Maps are off significantly from my Data
mbroadwayTN8HK
mbroadwayTN8HK
Hi everyone. I have two drawings, one in which correct imagery will show up and one will not. They both share the same coordinate system and data. I am very new to this location setting feature and not to savvy on how to remedy this.
Replies (8)
tcorey
Are both drawings set up with an assigned coordinate system? See: Edit Drawing Settings, Units and Zone tab.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
mbroadwayTN8HK
Yes, they are set to the same coordinate system. TX83-NCF
mbroadwayTN8HK
mbroadwayTN8HK
It looks as though the rotation is off or something. I believe the 2 dwgs have different geo markers
Pointdump
Mason,
Did you use the GeoLocation Command on the incorrect drawing? GeoLocation is meant for Vanilla AutoCAD and is wonky and unpredictable in Civil 3D.
Easiest fix is to use GEOREMOVE Command, MAPCSASSIGN to re-assign the Coordinate System, then GEOMAP to see Bing Live Maps.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
mbroadwayTN8HK
Thank You very much, removing and resetting the coordinate system worked.
tcorey
@Pointdump I'm going to start calling you PointGump. You're a dad gum genius. 😉
Tim Corey
Redding, CA
ChicagoLooper
How do you assign a coordinate system to your drawing so it'll be consistent with Bing Maps? Easy, assign your coordinate system then turn on Bing Maps. Here's a video that demonstrates how to assign Nevada State Plane, NAD83, East Zone, US Feet. (Your state and zone may vary.) Once you've assigned your coordiante system, simply turn on Bing Hybrid map (use the Hybrid version so you'll have aerial photography and street labels, both will assist in getting your bearings as you zoom-in and pan around). Turning on Bing Maps after you've assigned your CS replaces other, more complicated procedures, commonly used set up georeferencing.
To watch the video you may click >>HERE<<.
After you have turned on Bing, a red geomarker will appear in modelspace. Using your mouse wheel to zoom-out gives you a wider view angle and makes it easier to find the geomarker. When you spot the marker, pan to it then zoom-in. Get in tight so you can read the labels provided by Bing Hybrid and to get your bearings.
Chicagolooper
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
