Civil 3D Forum
Best Way to Grade Curb Ramps
13 REPLIES 13
Message 1 of 14
SBoninJB57Y
777 Views, 13 Replies
Hey Everyone,
I am just wondering what your preferred method of grading curb ramps are? Almost all of my design projects have curb ramps that are in curb extensions, and I have to meet existing back of walk and existing edge of road while staying within slope parameters. Is it Corridor, Grading Object, Feature Lines, something else?
Thanks!
13 REPLIES 13
Message 2 of 14
pendean
in reply to: SBoninJB57Y
Are you using Civil3D or some add-on for civil?
Message 3 of 14
EliANewlines
It's difficult to give a general answer, because there are so many types of curb ramps and a lot depends on the exact site, but for most curb ramps I use feature lines (top/bottom/sides of ramp, flares, cheek walls, etc.) and I manually adjust the elevations to ensure it's within slope parameters.
Message 4 of 14
Joe-Bouza
IMHO if they are dimensionally sound the grade fall out.
you can run the corridor typical section and build the surface then drape FL over the Ped ramp and past together in a composite surface.
you can ad regions or conditional assemblies that drop the curb and target the back
Transsoft has a dedicated grading tool
Joe Bouza
Message 5 of 14
SBoninJB57Y
in reply to: pendean
I am using Civil3D
Message 6 of 14
SBoninJB57Y
in reply to: Joe-Bouza
Thanks for the response, what do you mean if the ramps are dimensionally sound?
Message 7 of 14
Joe-Bouza
If the typical section is say for a 6" curb reveal, the length of flares, depth of throat make the ramp ADA compliant.
One of our municipalities refuses to show elevations. Only dimension
Joe Bouza
Message 8 of 14
I'm a big fan of the new corridor workflow, particularly since the 2024.4 update. Using a corridor transition to control the curb height and then adding feature lines for the rest of the ramp.
I spend time on this forum because I enjoy Civil 3d and getting your likes.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Message 9 of 14
Wow, we're not at 2024 yet. What is your workflow? That looks great.
Message 10 of 14
Ooooo! That is big. Cant wait to use it
Joe Bouza
Message 11 of 14
I will try to record a video - today isn't crazy busy, I think everyone is mentally on the 4th of july holiday.
Message 12 of 14
When is the 4th of July! 😮
Joe Bouza
Message 13 of 14
Found time to record that video.  This is more general about the feature line corridor workflow, rather than just curb ramps.  I do cover curb ramp and corridor transtion, but I don't do the basic feature line part.
https://youtu.be/Gg7u9-LgIL0
Message 14 of 14
Incredibly helpful. Thank you.
Rail Community
