Civil 3D Forum
BasicLaneTransition assembly with multilayers
3 REPLIES 3
jennyk111
183 Views, 3 Replies
I am using BasicLaneTransition because I want to adjust the location and elevation of the lane with an alignment. I need to model multiple pavement layers, but the BasicLaneTransition has only one layer available. Is there another subassembly with the possibility to tie it to an alignment and profile and add multiple sublayers for the corridor?
Labels (1)
3 REPLIES 3
civilman1957
in reply to: jennyk111
I was able to use the "LaneOutsideSuperMultilayer" and manipulate it both horizontally and vertically with a feature line. It has quite a few pavement and subbase layers, but you can give 0 depths to the ones you don't want to use...
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
jennyk111
in reply to: civilman1957
Thank you @civilman1957! I didn't realize that other subassemblies too can be manipulated with a alignment in a same way.
civilman1957
You're quite welcome...it took me a while to discover it, too...glad to help...
Rail Community
