Civil 3D Forum
Background mask color doesn't change! (photo attached)
5 REPLIES 5
Reza-WE
962 Views, 5 Replies
I'm trying to get rid of the dark background mask for contour labels. I've attached the settings.
5 REPLIES 5
Jeew-m
in reply to: Reza-WE
Just above the color select option you have the option to remove background mask. Set the value to FALSE.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
user181
Hi @Reza-WE  The mask turns dark like that if there is a transparency set on the layer assigned to the label in the label style. find the layer for your labels and set the transparency of that layer to 0 in the layer properties manager.
Reza-WE
in reply to: Jeew-m
I need the mask. If I turn it off, it will show the contour line behind the text.
Reza-WE
@user181 @Jeew-m
I figured it out! it was on the properties Masking dropdown menu. Thanks guys.
Reza-WE
in reply to: user181
You are right. I set transparency to 0 for alignment and feature line labels and it fixed it. Thanks
Rail Community
