Hi
I want to run a script in accoreconsole to plot some drawings.
The problem is that since accoreconsole uses the profile called <<Unnamed Profile>> it doesn't load the same plotters and plot styles as with my regular profile.
When I look in the registry where the <<Unnamed Profile>> is located I can find it under CURRENT_USER for ACAD-7101:409, which means AutoCAD 2024, not Civil3d 2024 which is ACAD-7100:409 and here I can find my profile!
I just work with Civil3d, and I wish to have accoreconsole use the same profiles. How can I make accoreconsole find my regular Civil3d profile?
Thanks!
What about exporting your C3D profile with the correct printer preferences/files paths, export the .arg file, import into Autocad and rename it <<Unnamed Profile>>?
Thanks for your suggestion, I'll try it out . But it sounds a bit cumbersome. I'd prefer to be able to script it somehow if possible...
