Automatic Split Profile Views
pedro_sam_machado
pedro_sam_machado
Good afternoon! I’m trying to set up profile views for a very long project, which makes it difficult to do the work manually. The problem is that Civil 3D’s automatic split option is presenting many issues, making it an unreliable solution. When using Automatic Split with Station Rounding and Datum Rounding set to ‘Previous minor grid,’ Civil 3D does not generate the splits correctly. Does anyone know how to configure this properly, or suggest a solution using Dynamo or Python?
igi_pop
Hey!
Works for me (See screenshot), and the one with the setup.
It works however I set it up.
HOWever, you have to keep in mind that, if you lock to minor station/elevation, the minor stations/elevation have to be a divisor of the desired height. So, if you entered 18, you should use 1, 2, 3, 6 or 9. Else, i guess it could snap to scarsley.
Try to setup EXACT station and datum, select your Height, and see what happens 🙂
Also, if you have a profile view style that shows elevations on both vertical axes outside, it might be confusing to read the elevations one next to the other.
Cheers,
Iggy
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
rosie_lucas1
Hello @pedro_sam_machado,
Did the information provided by @igi_pop help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie | Community Manager
Let us know how we did on Trustpilot.
Rosie
