Automatic Linework
Automatic Linework
Message 1 of 12
Automatic Linework
Is it possible to generate the automatic line work  from csv file and description keys?
Thank you for your help.
Replies (11)
Message 2 of 12
chriscowgill7373
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2017/...
You can generate automatic linework, but you would need to set up a figure prefix database, and figure styles to go with it.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 3 of 12
Just to confirm it might be done without survey database correct?
Message 4 of 12
chriscowgill7373
Figures would be created utilizing the survey database. I'm not aware of a way to generate linework in c3d tied to points without it.
Message 5 of 12
Thank you for the reply.
Let me try it following the steps that provided at the link.
Message 6 of 12
Pointdump
Sofia,
Without using the Survey Database, you could use an old school <<<AutoCAD Script>>>. More info <<<Here>>>.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 7 of 12
The Sincpac set of addins has a connect COGO points command.  It connects selected COGO points of the same description in ascending point number.
http://www.quuxsoft.com/SincpacC3D_Download.aspx
Message 8 of 12
Dave,
Thank you for the reply. Although it didn't work for me. I followed the steps, and when i run _script command it asks me for "specify a point". I thought it should bring all points according to their coordinates.
Sofia
Message 9 of 12
Thank you.
Although I would like to be able to do it without addins.
Message 10 of 12
Pointdump
Sofia,
"...bring all points according to their coordinates."
It will. Does your Script File look like this? (Note the Space in last row.)
LINE
711311.59,26777211.98,1368.55
712128.49,26775839.39,1327.66
714242.37,26773493.52,1261.33
712804.62,26775873.85,1308.42
711281.94,26777136.56,1365.33
715640.72,26776790.13,1255.32
710967.05,26773034.97,1272.82
I've attached a Script File that I was playing with this morning.
Dave
Dave Stoll
Las Vegas, Nevada
Message 11 of 12
tboehler
You may already be aware of these options to create lines after you have the points imported?  Create lines by # or range of #'s, name, object, ect.
Message 12 of 12
Thank you.
It worked for me. I had to set up 3 components: Description keys, Figure Prefix Database and Linework code sets before importing csv file into my drawing.
