I have this problem that Autocad manage to print everything on A3 size but when I try to print of A4, the 1st character (text) on the left (be it in the table or not) will not be printed out. Printing it to PDF doesn't post any problem as everything came out as the way it should. This only occurs when printing on A4 directly from Autocad. "Fit to paper" settings is applied and print out from the pdf to A4 is also fine.
What settings do I have to change in order to make the 1st character print when printing on A4?
