Civil 3D Forum
Autocad civil 3d 2018 and Autocad 2018 have a common launcher
3 REPLIES 3
849 Views, 3 Replies
I install autocad 2018 and autocad civil 3d 2018, they have the same launcher location with a common icon called acad.exe, if i lost the autocad civil 3d desktop shortcut icons how can i get them back?
3 REPLIES 3
Jeew-m
Dear Friend,
If you are using Windows 7 OS you can click on the start button and at the search you can type Civil 3D. Then it will show all available versions.
Right click on any version you need to create a short cut.
In the menu go to Send To.
Choose Desktop (Create Shortcut)
Same can be apply if you search for auto cad by changing words.
And follow similar search procedure if you are using windows 8 or above.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
M_c3d
Make sure you have ticked created desktop shortcut during install. This can be added under modifying the program in the control panel
BushW
Hello @Anonymous
I see that you are visiting as a new member to the AutoCAD Civil 3D forum. Welcome to the Autodesk Community!
I'm just following up to see if you need more help with this. Did the reply of @Jeew-m provide work for you?
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit and thank you for doing so, and I'm here to help.
Best Regards,
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
Rail Community
