Civil 3D Forum
Autocad civil 2015
4 REPLIES 4
305 Views, 4 Replies
Autocad civil 2015
the  new feature appearing in the pic is no more active on my civil 3d 2015
the data of the arc  ( radius and angle ) when you select the arc and point at the midpoint
4 REPLIES 4
rkmcswain
Set DYNMODE = 3.
Any different?
R.K. McSwain     | CADpanacea | on twitter
AllenJessup
You can also set "Enable Dimension Input where possible" on the Dynamic Input tab of Drafting Settings. Checking that plus the "Enable Pointer Input" will set DYNMODE to 3. Same solution - different route.
Allen
Allen Jessup
CAD Manager - Designer
in reply to: rkmcswain
Thanks alot much appreciate
in reply to: AllenJessup
Thanks alot allen
Rail Community
