attribute table to create object data missing
ntanVF8MF
Observer Observer
Message 1 of 9
ntanVF8MF
Observer
Observer
I'm bringing shapefiles into civil 3D and when i click on data to create object data no pop-up display appears - its entirely disappeared. I would assume it might be off screen somewhere but this hasn't happened before. I've been able to create object data perfectly fine in the past and only suddenly is the pop up missing.
Is there any solution to this or some way to reset? 😞
thank you
Replies (8)
Message 2 of 9
Pointdump
Hi @ntanVF8MF,
The only thing that occurs to me is to check the DBF file. It might be empty. Drag-n-Drop the shapefile into your drawing and open the Attribute Table. What does it show?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 9
ChicagoLooper
Hi  @ntanVF8MF
<<...I'm bringing shapefiles into civil 3D and when i click on data to create object data...>>
What does this mean? Are you bringing in shapefiles as a Feature Data Object (FDO)?
1-Adding a Shapefile using a Data Connection.1-Adding a Shapefile using a Data Connection.
If not a Data Connection, then are you using MapImport?
2-Adding a shapefile using MAPIMPORT command.2-Adding a shapefile using MAPIMPORT command.
The method you use to 'bring in' the shapefile plays a big role in describing your issue and a step-by-step solution is incumbent upon you describing your end goal. Please explain your expectations using your specific workflow, whatever that workflow may be.
Chicagolooper
Message 4 of 9
lim.wendy
Hi @ntanVF8MF,
Welcome to the Civil 3D forum.
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts? Please also share more details as requested so we can assist you. Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 5 of 9
ntanVF8MF
Observer
Observer
Hi, thanks for responding.
I use MapImport and when I click the three dots to open 'attribute data' (like your image) and it does not show up. Attached is a screenshot of my screen when i try to open the attribute data - the mapimport tab fades out and im unable to click anywhere on the screen.
quite an odd issue. the attribute data used to pop up fine like normal but now it's disappeared.
PS Ive also tried restarting, uninstalling Civil, minimised my screen etc.
Message 6 of 9
ntanVF8MF
Observer
Observer
the problem right now is that the attribute table does not pop up anymore after i do a mapimport of my shapefile:(
Please see my response to one of the other replies detailing what happens.
appreciate your suggestion and help though, thanks for responding
Message 7 of 9
Pointdump
@ntanVF8MF,
Thanks for posting the screen shot. Does this happen with all shapefiles, or just this one? Can you post your shapefile?
Do you have all updates for your 2023: AutoCAD, Map, and Civil?
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 9
lim.wendy
Sounds like the window may be off-screen and is no longer viewable. Try the steps in the following article:
Dialog box windows are not displayed in AutoCAD products
Wendy Lim
Rails Summit
Message 9 of 9
lim.wendy
Hi @ntanVF8MF ,
Did you manage to get this sorted?
Let us know if you still have questions.
Wendy Lim
Rails Summit
