Civil 3D Forum
Attribute data not importing from shape files
10 REPLIES 10
Message 1 of 11
joeperkins_gai
589 Views, 10 Replies
When I import shape files into AutoCAD C3D 2020 using MAPIMPORT command, I do not always get the attribute data. I choose the "Create object data" option and make sure all the fields are selected, but I only end up with a polyline. The shape file has all the associated files in the same folder. Is there a new patch out there?
Joe
10 REPLIES 10
Message 2 of 11
Joe-Bouza
in reply to: joeperkins_gai
Joe
You are saying When you export you create OD, right?
can you share you dwg and shp
Joe Bouza
Message 3 of 11
Hi @joeperkins_gai
Can you see Object Data in Property Palette?
Arturo Polanco
AEC Solutions Specialist - Civil Infrastructure
Youtube | Twitter
Message 4 of 11
Like Joe said, select create object data, and then in the pop-up also select Create Object data.  If necessary, you can limit the data imported.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 5 of 11
Pointdump
Hi Joe,
Here's something to check. If your drawing already has an Object Data Table of the same name, it won't add any attributes. Use command ADEDEFDATA to see.
As @Joe-Bouza says, it would be best to post your shapefile and drawing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 6 of 11
joeperkins_gai
in reply to: Joe-Bouza
I do not create the shape file. These are from FEMA
Message 7 of 11
No. It might work once then not at all.
Message 8 of 11
Hi @joeperkins_gai
The error might be, might NOT be, an error during the MapImport procedure.
If you really want to get to the bottom of it, invest a few minutes and run an experiment.
First, run MapImport on the shapefile (be sure to Create Object Data during import). Second, while in the same dwg, bring in the exact same shapefile using a Data Connection.
<<You can toggle shapefile (display/hide) in the Map Task Pane.>>
Now that you have both (a) the shapefile and (b) the imported line work on top of one another in modelspace, you can see how the AutoCad OD compares to the ESRI Table. If the OD is consistent with the Table then it’s all good. If not then analyze your MapImport procedure. You may have imported a copy of the shapefile, not the original. Or you may have skipped the ‘Create Object Data’ part during import.
Shapefile minimum:
  1. shp
  2. shx
  3. dbf
  4. prj
All 4 components must be in the same folder. If the dbf is in a separate folder (or nonexistent), then Create Object Data will fail.
Chicagolooper
Message 9 of 11
joeperkins_gai
in reply to: Pointdump
I do not use this forum often so am not sure how to post files.
Message 10 of 11
Chicagolooper
Message 11 of 11
Thanks everyone for your input but it just seems like a glitch in my profile since it works sometimes and sometimes not. I will be upgrading to 2023 so hopefully it will work itself out.
Rail Community
