Assembly Add Point Elevation
chan230984
Message 1 of 8
chan230984
Hi, All
From Basic Assembly, How to Add Elevation in Midpoint
Thanks..
Replies (7)
Message 2 of 8
KMercier_C3D
Add a LinkWidthAndSlope (from the Generic tab of the tool palette), set the width as half the lane and set OmitLink=Yes. In the Assembly Properties on the Construction tab check the checkbox for Use Parameter Reference and set the dropdown to the Lane Slope.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Message 3 of 8
chan230984
@KMercier_C3D
I make something Wrong, why is not work
Message 4 of 8
CivilFlow
Hello did you "omit the link" like Kati recommended?
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Message 5 of 8
KMercier_C3D
Did you use the drop-down next to the checkbox to select the lane slope output parameter?
You may also need to change the point code depending on your settings.
Pronouns: She/Her
Message 6 of 8
chan230984
I share my files, please check.
Message 7 of 8
Dexterel
I added a brake line to surface.
I think you say middle of lane (3.60/2=1.80), yo can check the dwg.
Message 8 of 8
Dexterel
and the dwg 😄
