Anybody here use PA GIS data?
jmayo-EE
Mentor Mentor
Message 1 of 46
jmayo-EE
If anyone knows what is going on with PA GIS data I would love to hear about it.
Orthoimagry says it's in PA83-SF (NAD 83 state palne south) feet. I pop it into a file with the same coord sys using mapiinsert and everything scales 3.2 times larger....metric?
County boudaries, roads and water courses imported from shp file say the shp has a coord sys of antartica98.LL assigned. Nothing imported scales correct or is in proper coords. Why would PA use antartica??
John Mayo
Replies (45)
Message 2 of 46
Pointdump
John,
You've already put your finger on the problem:
"Problem with the internet is you can't always trust the sources"
Where are you getting your data?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 46
jmayo-EE
Well I couldn't find anything for Bucks County here,
http://www.pasda.psu.edu/uci/SearchResults.aspx?shortcutKeyword=aerial&searchType=shortcut&sessionID...
So I went to the USDA for aerials.
http://earthexplorer.usgs.gov/
As for the GIS data I was here,
John Mayo
Message 4 of 46
Todd_Rogers
More than likely it's in Metric.  I can convert it for you if you like.  Give me info on what to download and I will download it and convert it for you.
Todd Rogers
Civil Administration
Message 5 of 46
jmayo-EE
Oh wow Todd, very cool but I need counties, roads and municipalities. May be shorter if you could provide me a workflow. I would appreciate it.
John Mayo
Message 6 of 46
Todd_Rogers
Well, the workflow is use Global Mapper...lol.  That's what I use.  Extremely powerful program for the price.  I think it's like $400 now.  It will literally open up 100's of file types and you can convert and reproject to any coordinate system with a click of a button.
http://www.bluemarblegeo.com/products/global-mapper.php
Todd Rogers
Message 7 of 46
jmayo-EE
Dang. I won't get that $$ from the powers that be.
I checked the web site, didn't say if the evaluation os fully functional. I will check on Mon.
Does the offer still hold if the demo won't do what I need? 🙂
John Mayo
Message 8 of 46
Todd_Rogers
Yes sir.
Todd Rogers
Message 9 of 46
Pointdump
John,
Here's a Pennsylvania Counties shapefile from ESRI to get you started.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 46
Someone made a mistake when creating the shapefile. The LL Antarctica is the first system on the list and he/she forgot to assign the correct coordinate syestem. You might check the Penn State clearinghouse for data.
Message 11 of 46
Pointdump
John,
The hardest part is digging up the sources. There's a world of data out there to sift through.
Here's some possible data sources:
http://www.pamap.dcnr.state.pa.us/pamap/data_source.aspx
http://data.geocomm.com/catalog/US/61062/index.html
http://pa.water.usgs.gov/infodata/gisdata.php
And here's a good place to get contours:
http://opendem.info/download_contours.html
Dave
Dave Stoll
Las Vegas, Nevada
Message 12 of 46
Pointdump
John,
Here's a couple of Bucks County Shapefiles, Roads and Waterways.
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 46
jmayo-EE
Dave Todd
U guys r awesome. Thx a bunch. I'll get back to this mon.
Thx again
John Mayo
Message 14 of 46
jmayo-EE
I am astonished that the whole PA dataset is useless in C3D.
Todd if you don't mind, could you look at these and see if you can make sense of them? I need them in a PA NAD83 state plane south.
John Mayo
Message 15 of 46
jmayo-EE
Here's a link to the municipalities.
http://www.pasda.psu.edu/uci/MetadataDisplay.aspx?entry=PASDA&file=PaMunicipalities2015_01.xml&datas...
The streams posted above would also be nice.
Thanks a bunch if you can asist me.
John Mayo
Message 16 of 46
Todd_Rogers
Got it.  Working on it now.  Stay tuned, it should only take me a sec...
Todd Rogers
Message 17 of 46
Todd_Rogers
Here you go...
Todd Rogers
Message 18 of 46
jmayo-EE
Dave,
Do you check any units on that data? I nsert those shp files and the data set is at the origin and way to small to be a state or even a town...
Even the 2010 ortho imagery needs to be inserted into a metric template to get things to scale. Unfortunately the file is saved in meters but the distances scaled in that file are feet. Inserting it into a metric template is the only way to get a parking stall to come close to 9'x18' to 10'x20'.
John Mayo
Message 19 of 46
jmayo-EE
Awesome!!
Now if you and Dave just reply with the solution, "PA GIS data is useless in C3D due to the fact that the goverment hired someone (more than likely an intern) to map this that knows nothin about mapping this". I can give you guys the solution. 🙂
John Mayo
Message 20 of 46
Pointdump
John,
Unzip, then drag-n-drop those shapes into a blank drawing. Autocad will automatically assign a coordinate system and you'll be able to look at what you've got.
Dave
Dave Stoll
Las Vegas, Nevada
