Civil 3D Forum
Annotative text not visible in viewport
3 REPLIES 3
27553 Views, 3 Replies
Is there a reason my annotative Mtext is not visible in my viewport? The only way I can get it to show up is if I make it non-annotative, which defeats the purpose.
3 REPLIES 3
Sinc
You have to make sure your annotative object has the proper Annotative Scale attached to it. Right click -> Annotation Scales. The list should contain the scale you are using in your viewport.
You may also want to check into ANNOAUTOSCALE.
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.com
Sinc
Make sure Annotation Visibility is turned on. It should be an icon in the lower right corner of your screen in paper space.
HOW DO I MNAKE SURE THIS STAYS ON AT ALL TIMES?
Rail Community
