alignment correction
Greetings All.
I am designing a road using Civil 3D 2022. While I am working on my alignments, I got the following (please look at the attached pic). I could not correct the output. Can I get some Help?
for your info, I have collected the lat long data for the making of the contour map from google earth pro. what i have seen from the data is that the lat long data are in degrees and the length of the alignment is may be in degrees. may be it is related with this.
Pointdump
Hi Solomon,
Your alignment is all bunched up because AutoCAD thinks those Degree Units are Meters. Attached, please find a drawing assigned UTM84-37N Coordinate System which brings your points into Sodere, Ethiopia.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
