follow up on the question re:"Alignment correction"
Message 1 of 11
here is the data i have used the csv file
emilio valentin please be informed
Replies (10)
Message 2 of 11
wfberry
What point file format did you use?
Message 3 of 11
wfberry
Is this area in Ethiopia?
Message 4 of 11
Pointdump
Solomon,
To expand on Bill's mention of the Point File Format, here is what you'll need to bring them into a UTM84-37N Metric Drawing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 5 of 11
ChicagoLooper
Yes. If you are trying to build a surface, then you can do it using Civil3D. .
You don't need to use another software. You can use the MAPIMPORT command. The MapImport command is from the Map3D Toolset (from the Planning and Analysis workspace) and it can read your csv file exactly as it is written. You don't need to manipulate the CSV file or modify any Civil settings or formats.
Open a Civll3D metric template then assign the coordinate system named Adindan.UTM-37N (EPSG 20137). This coordinate system uses units of meters and is the coordinate system I used. Although your specific coordinate system may vary, be sure to select one that uses meters, not degrees.
Next follow these steps.
Enter MAPIMPORT on command line. Or you may use the ribbon: change to Planning & Analysis Workspace=>Insert Tab=>Import Panel=>Map Import Icon=> browse to and select your CSV=>OK
In the import window make your selections like this. Be sure to select NEZ (comma delimited) from the Select Formatting dropdown. You’ll need to tell AutoCAD the CSV coordinates are in Lat/Long degrees format. Because the CSV format is not the same as your modelspace coordinate system, you’ll to select LL84 when you’re importing your points.
Wait one or two minutes (your time may vary depending on your specific computer) and your points will appear. (The points will actually be blocks, keep them as blocks.) You may need to ‘zoom extents’ to see the points. When you see your points they’ll be too large. Select all the points using a crossing window then adjust the Scale to 25. Adjust the x, y, and z values.
In Toolspace create a surface. For you surface definition select Drawing Objects=>Add=>Blocks=>Select all the Blocks. Your surface will be created. You may turn on Bing maps.
Chicagolooper
Message 6 of 11
CSV file format
Message 7 of 11
sure
Message 8 of 11
CSV format
Message 9 of 11
CSV
Message 10 of 11
thanks. I have used it and i did get what i want
Message 11 of 11
thanks
