I have copied the sample as below. This is the Geotechnical data file to store the borehole data. Thks
"**PROJ"
"*PROJ_ID","*PROJ_NAME","*PROJ_LOC","*PROJ_CLNT","*PROJ_ENG","*PROJ_CONT","*PROJ_DATE","*PROJ_AGS","FILE_FSET" "","","","","","","dd/mm/yyyy","",""
"7845","Trumpington Sewerage","Trumpington","Trumpington District Council","Geo-Knowledge International","Lithosphere Investigations Ltd","23/07/1999","3","FS0001"
"**HOLE"
"*HOLE_ID","*HOLE_TYPE","*HOLE_NATE","*HOLE_NATN","*HOLE_GL","*HOLE_FDEP","*HOLE_STAR","*HOLE_LOG","FILE_FSET" "","","m","m","m","m","dd/mm/yyyy","",""
"TP501","TP","523196","178231","61.86","3.25","21/07/1999","ANO","FS002"
"BH502","IP+CP","523142","178183","58.72","15.45","22/07/1999","ANO","FS003"
"**GEOL"
"*HOLE_ID","*GEOL_TOP","*GEOL_BASE","*GEOL_DESC","*GEOL_LEG","*GEOL_GEOL","*GEOL_STAT","FILE_FSET"
"","m","m","","","","",""
"TP501","0.00","0.25","Friable brown sandy CLAY with numerous rootlets (Topsoil)","101","TS","A",""
"TP501","0.25","1.55","Firm brown slightly sandy very closely fissured CLAY with some fine to coarse subrounded gravel. Medium spaced subhorizontal slightly polished gleyed shear surfaces. Widely spaced vertical rough desiccat","","","",""
"","","","ion cracks with concentrations of rootlets. (Weathered Boulder Clay)","261","WBC","B",""
"TP501","1.55","3.25","Stiff grey closely fissured CLAY with a little fine to medium subrounded gravel and rare sandstone cobbles (Boulder Clay)","250","BC","C",""
"BH502","0.00","0.30","Friable brown sandy CLAY with numerous rootlets (Topsoil)","101","TS","",""
"BH502","0.30","2.60","Firm brown very closely fissured CLAY with a little fine to medium subrounded gravel (Weathered Boulder Clay)","250","WBC","","" "BH502","2.60","5.75","Stiff grey slightly sandy closely fissured CLAY with some fine to coarse subrounded gravel (Boulder Clay)","261","BC","","" "BH502","5.75","15.45","Dense becoming very dense yellow brown very sandy fine to coarse subrounded GRAVEL (Glacial Gravels)","307","GG","",""
"**SAMP"
"*HOLE_ID","*SAMP_TOP","*SAMP_REF","*SAMP_TYPE","*SAMP_BASE","*SAMP_DATE","*SAMP_TIME""*GEOL_STAT","FILE_FSET" "","m","","","m","dd/mm/yyyy","hhmmss","",""
"TP501","1.00","1","D","1.00","","","B","" "TP501","1.00","2","B","1.30","","","B","" "TP501","2.50","3","B","2.75","","","C","" "BH502","1.00","1","U","1.45","","","","FS058" "BH502","1.50","2","D","1.50","","","","" "BH502","3.00","3","U","3.45","","","","" "BH502","3.50","4","D","3.50","","","","" "BH502","6.00","5","D","6.45","","","","" "BH502","6.00","6","B","6.50","","","","" "BH502","9.00","7","D","9.45","","","","" "BH502","9.00","8","B","9.50","","","","" "BH502","10.00","9","B","10.50","","","","" "BH502","12.00","10","B","12.50","","","","" "BH502","3.00","11","W","3.00","22/07/1999","120000","","" "BH502","3.00","12","W","3.00","22/07/1999","153000","",""
"**CLSS" "*HOLE_ID","*SAMP_TOP","*SAMP_REF","*SAMP_TYPE","*SPEC_REF","*SPEC_DPTH","*CLSS_NMC","*CLSS_LL","*CLSS_PL" "","m","","","","m","%","%","%"
"BH502","1.00","1","U","A","1.10","28","56","22"
"BH502","1.00","1","U","B","1.25","31","62","24"
"BH502","3.00","3","U","","","28","53","28"
"BH502","3.50","4","D","","","24","",""
"**CNMT" "*HOLE_ID","*SAMP_TOP","*SAMP_REF","*SAMP_TYPE","*SPEC_REF","*SPEC_DPTH","*CNMT_TYPE","*CNMT_TTYP","*CNMT_RESL","*CNMT_UNIT" "","m","","","","m","","","",""
"BH502","3.00","11","W","","","PHS","WATER","7.2","" "BH502","3.00","11","W","","","SULWS","WATER","0.037","g/l" "BH502","3.00","11","W","","","CL","WATER","51","mg/l" "BH502","3.00","12","W","","","SULWS","WATER","0.040","g/l"
"**ISPT"
"*HOLE_ID","*ISPT_TOP","*ISPT_NVAL","*ISPT_REP","*?ISPT_CORN","*?ISPT_EXTP","*ISPT_TYPE"
"","m","","","","","" ~
"BH502","6.00","37","8,9/9,10,10,8 N=37","","","S"
"BH502","9.00","45","5,7/8,10,12,15 N=45","30","","S"
"BH502","12.00","","15,18/20,30 (50/120)","","125","C"
"**DETL"
"*HOLE_ID","*DETL_TOP","*DETL_BASE","*DETL_DESC"
"","m","m",""
"BH502","3.20","3.45","3.20-3.45m Boulder of yellow brown sandstone, weak"
"BH502","5.00","5.00","5.00m Becoming very stiff"
"BH502","8.50","9.70","8.50-9.70m Fine sand"
"**DICT"
"*DICT_TYPE","*DICT_GRP","*DICT_HDNG","*DICT_STAT","*DICT_DESC","*DICT_UNIT","*DICT_EXMP" "HEADING","ISPT","ISPT_CORN","COMMON","Corrected N value in sand","","20"
"HEADING","ISPT","ISPT_EXTP","COMMON","Extrapolated N value","","151"
"**ABBR"
"*ABBR_HDNG","*ABBR_CODE","*ABBR_DESC"
"HOLE_TYPE","CP","Cable percussion (shell and auger)"
"HOLE_TYPE","IP","Inspection pit"
"HOLE_TYPE","TP","Trial pit/trench"
"GEOL_LEG","101","Topsoil"
"GEOL_LEG","250","CLAY with a little gravel"
"GEOL_LEG","261","Slightly sandy CLAY with some gravel"
"GEOL_LEG","307","Very sandy GRAVEL"
"GEOL_GEOL","TS","Topsoil"
"GEOL_GEOL","WBC","Weathered Boulder Clay"
"GEOL_GEOL","BC","Boulder Clay"
"GEOL_GEOL","GG","Glacial Gravels"
"SAMP_TYPE","B","Bulk disturbed sample"
"SAMP_TYPE","D","Small disturbed sample"
"SAMP_TYPE","U","Undisturbed sample - open drive"
"SAMP_TYPE","W","Water sample"
"ISPT_TYPE","C","Cone"
"ISPT_TYPE","S","Split spoon"
"CNMT_TTYP","WATER","Water"
"**CODE"
"*CODE_CODE","*CODE_DESC"
"PHS","pH"
"SULWS","Sulphate"
"CL","Chloride"
"**UNIT"
"*UNIT_UNIT","UNIT_DESC"
"m","metre"
"dd/mm/yyyy","day month year"
"hhmmss","hours minutes seconds"
"%","percentage"
"g/l","grams per litre"
"mg/l","milligrams per litre"
"**FILE"
"*FILE_FSET","*FILE_NAME","*FILE_DESC","*FILE_TYPE","*FILE_PROG","*FILE_DATE"
"FS001","siteplan.dwg","Trumpington Sewerage site plan","DWG","AutoCAD Version 14","24/08/1999"
"FS001","text.doc","Trumpington Sewerage geotechnical report text","DOC","Word97","24/08/1999"
"FS002","tp501p01.jpg","Trial Pit TP501 photograph - east face","JPG","PaintShop Pro Version 5.0","21/07/1999"
"FS002","tp501p02.jpg","Trial Pit TP501 photograph - west face","JPG","PaintShop Pro Version 5.0","21/07/1999"
"FS003","bh502p01.jpg","Borehole BH502 inspection pit photograph","JPG","PaintShop Pro Version 5.0","22/07/1999"
"FS058","labp39.jpg","Borehole BH502 photograph - split U100 sample 1.00-1.45m","JPG","PaintShop Pro Version 5.0","20/08/1999"
