AEC Tin Surface - Not showing after attached in Xref
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My issue is with a survey file that has a Civil 3D surface (AEC tin) in it not being visible after it's xref-attached through multiple files.
In our office, we do our work in a design file that has the survey file xref-attached into it. We then attach our design file CAD base to a plot sheet so all of our sub-consultant files are carried through via the single design file.
The issue is the tin surface is entirely visible in the design base after the first xref-attach, but then as we xref the design base to the plot file, the tin is not carried through. All other linework associated with the survey file carries through. I have verified this with different survey files with AEC Tins and the same thing happens, so it does not appear to be an isolated issue.
I have not experienced this issue with other versions of CAD.
-I am working in ACAD 2019 with recent updates that were sent out. I have 2019 Object Enablers installed.
-I have verified the plot sheet SHOWS the TIN surface while viewed in Civil 3D 2019 (w/ recent update installed).
Can I get this investigated further? Could there be a need for a new object enabler release?
Thanks.
