Civil 3D Forum
AddNetworkPartProfLabel won't label structure
6 REPLIES 6
julie.cantu
408 Views, 6 Replies
Hello all,
I am trying to label  my manholes on plan view and in profile view.
When I try to add a label, the commands aren't recognizing the manholes
This is what happens (view pic)
I get the same message when I try to label in plan view as well. I am fairly new to Civil 3D so I am not too sure what is going on. Please help!
Thank you
6 REPLIES 6
MMcCall402
in reply to: julie.cantu
Check the command settings for the AddNetworkPartProfileLabel command in Toolspace to see if it has a valid label style specified.
Also check to see if the label style being used has valid style settings for things like layer, text style and content.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
wfberry
Thaw all layers
Turn on all layers
See if that helps.
Bill
MMcCall402
in reply to: wfberry
<head smack>  Yes, turn layers on. Layer 0 too.
Mark Mccall
CAD Mangler
Linkedin
julie.cantu
in reply to: MMcCall402
I feel like a dummy, when I turned all layers on it worked for labeling on the plan view, but still does not work when trying to label in the profile, in fact the label that is in plan view is suppose to be in profile like it got switched around..... not sure how...Manhole label.PNG
wiatt89KVX
Can you note where to find that setting in Toolspace?
MMcCall402
in reply to: wiatt89KVX
Toolspace - Settings Tab- Pipe Networks - Commands
Mark Mccall
CAD Mangler
Linkedin
Rail Community
