Hello all,
I am trying to label my manholes on plan view and in profile view.
When I try to add a label, the commands aren't recognizing the manholes
This is what happens (view pic)
I get the same message when I try to label in plan view as well. I am fairly new to Civil 3D so I am not too sure what is going on. Please help!
Thank you
Check the command settings for the AddNetworkPartProfileLabel command in Toolspace to see if it has a valid label style specified.
Also check to see if the label style being used has valid style settings for things like layer, text style and content.
I feel like a dummy, when I turned all layers on it worked for labeling on the plan view, but still does not work when trying to label in the profile, in fact the label that is in plan view is suppose to be in profile like it got switched around..... not sure how...
