Adding new pipe sizes to parts list
Message 1 of 15
I am trying to draw in 2in. pvc pipe, but the smallest size that autocad comes with is 3.6in. I have tried using the parts builder, but after I added the size and saved it, it's still not in the options for different pvc sizes. I've also tried using the US Imperial pipes htm. but the browser comes up blank. I dont want to change anything else than the size of the pipe.
Any ideas?
Replies (14)
Message 2 of 15
jmayo-EE
In civil 3d type partcatalogregen and refresh the pipes and structures when you make edits.
John Mayo
PE, CFM, CME
alt="EESignature" width="244" height="22">
Message 3 of 15
lynn_zhang
Hello @Anonymous ,
Just checking to see if your problem has been solved. Did the response from @jmayo-EE help answer your question? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Message 4 of 15
Hello @lynn_zhang
I tried it but it didn't seem to help any. I've been busy recently and haven't played with it much after.
To make additional pipe sizes it opens up drawing called AeccCircularPvcPipe_Metric. Then in the Special Toolbox that the drawing has I click on size parameters, BdyD1 and then change one of the existing sizes to what I need. Then I click save part family in the same toolbox, but it gives the warning that the hide part flag is checked. If I uncheck it, It checks itself again when I click save. It also gives the warning that it was unable to save to kml. due to file being read-only, but I have checked the file and it is open.
Any Ideas?
Message 5 of 15
MMcCall402
Curious, you're looking to add a 2" pipe size but editing a metric pipe definition in partbuilder.
The value you will need to edit is the PID. You'll need to add a new value.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 6 of 15
Yes, Here everyone talks pipe sizes in Imperial. But I do all my work in metric, so I convert everything to metric.
Message 7 of 15
JasonArtley
There is a metric pipe catalog as well, have you tried using that one instead of converting the imperial?
Message 8 of 15
Yes, The smallest Pvc pipe the metric has is 75mm(3"). I need to add 51mm(2").
Message 9 of 15
Joe-Bouza
yes the smallest pvc in the catalog is 3 but 2 can be added
https://autode.sk/2WT8BHI
Joe Bouza
Message 10 of 15
I'm still having an error come up, (error saving xml file). I have removed the read only from the file.
Message 11 of 15
Joe-Bouza
is you catalog on the client od the server? is civil3d pointed to the correct catalog?
Joe Bouza
Message 12 of 15
I think so, how would I check to make sure?
Message 13 of 15
Joe-Bouza
Modify tab>> pipe Network >> set catalog path.
if you created the part list chances are you have it set correctly. If someone else created the part list it is possible it came from a different catalog
Joe Bouza
Message 14 of 15
Thanks for all the help. I'm not sure what fixed it, but it works now.
Message 15 of 15
lynn_zhang
Awesome! Glad to hear it works now. Thanks for letting us know!🙂
Lynn Zhang
