Adding mask to surface removes display of user contours
BrianHailey
Mentor Mentor
BrianHailey
Can someone confirm this for me? If I create a surface and do a user contour analysis, when I add a mask to this surface, the user contours no longer display. I just want to make sure I'm not loosing my mind. Civil 3D 2020.4.
Thanks!
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
cwr-pae
I'm getting the same thing in C3d 2020.5.2. Since i usually don't use masks I can't say if this is normal or bugged.
lim.wendy
Hi @BrianHailey@cwr-pae
Considering that the other surface analysis work, e.g, Elevation even with the surface mask applied, I'm seeing no reason why user-defined contours will behave differently.
I've seen these in a couple of different posts. I searched internally but didn't find anything logged. I will log this and share this with the product team.
Thanks for reporting this.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
mark_scacco_1
I'm experiencing the same issue in C3D 2022
Neilw_05
I would expect a Mask to eliminate everything within the mask. Why should we expect otherwise? Not sure what you are thinking Brian.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Neilw_05
I think I understand now. You are saying ALL user contours disappear, not just within the mask. I'll step aside.
WIN 10 64 PRO
mark_scacco_1
Yes ALL user contours are removed, including those beyond the mask boundary
