How to import vertical data for an alignment in c3d (.xml)
WASurveyGuy
Message 1 of 11
WASurveyGuy
Hi There:
I have a .xml file from a contractor that has a machine control alignment in it (horizontal and vertical).  Vertical data reads fine in our data collector.  How do I get the vertical component to come into c3d?  All I am getting is the horizontal alignment, with no vertical component, which is what I need most.  I've tried messing with the Osnapz value, going through the alignment settings and switching things off and on, but I can't seem to get it to go.  This seems like an extremely easy thing (or should be), especially in the age of machine control.
Any ideas?
Thanks!
Replies (10)
Message 2 of 11
Jeff_M
Can you share the xml file?
Jeff_M, also a frequent Swamper
Message 3 of 11
WASurveyGuy
Sure.
Message 4 of 11
Jeew-m
After importing xml you need to create a profile view. Then you can see the Vertical data.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 5 of 11
Joe-Bouza
The alignment is one thing and the vertical control another; the layout profile. It sound like the xml doesn’t distinguish and tries to apply elevation data to alignment in c3d and there is no place for alignment to hold z data.
if you can extract the station elevation part from the xml to space delimited txt then you can import profile from file
Joe Bouza
Message 6 of 11
Joe-Bouza
Special note: profiles created from file have an insidious behavior. They look like a layout profile design like one edit like one...You can create a DS with them but they will never update
Joe Bouza
Message 7 of 11
WASurveyGuy
Thanks everyone.  It appears C3d doesn't see it as a 3d line (like every other piece of software we have), but views it as separate vertical and horizontal components.  There was a profile and an alignment that came in to the drawing (I finally figured out).  What I had to do was to create a corridor, give it a dummy assembly, and only then could I pull the elevation data that I wanted, at certain points on the line in plan view (by generating a feature line, which included vertical, so I could create points on it, at elevation of the feature line).
Thanks again for all your help!
Paul
Message 8 of 11
Jeff_M
You can create a featureline directly from the alignment and profile, no need for the corridor.
Message 9 of 11
WASurveyGuy
Ok.  I'll try to figure out how to do that the next time this comes up.  Thanks!
Message 10 of 11
Jeff_M
This should help:
Message 11 of 11
cwr-pae
You can label any point on the alignment with the station & profile elevation in alignment labels.
