Adding Contours
Adding Contours
Message 1 of 9
Adding Contours
I am a 3rd year student and I am currently taking Highway Engineering Design course. Our professor gave us a sample of topographic map drawing in AutoCAD where we are supposed to create alignments, mass curve etc. Since i am in process of learning Civil 3D (very beginner), i am not sure how to add existing contours  lines into the civil 3d as a surface. I could do all this stuff using AutoCAD Mechanical which is a bit tedious but doable but since there is already a software for doing all of this, i prefer using Civil 3d. I am attaching the topographic map.
I appreciate if anyone could assist me on how do add theses contours to Civil 3d as a surface so then I can add horizontal and vertical curves etc.
Replies (8)
Message 2 of 9
L3GO-Ed
Hello arman, You could follow these Steps;
  1. Connect the Contour lines segments (in your drawing) to form the actual "3d contour polylines" of equal elevations. Use the join tool shown in snapshot 1; click on it once and then select all the lines. dont be bother AutoCAD will sort them out for you after that.
  2. Create a new tin Surface.
  3. Locate your newly created empty surface, find Contuors option under it, right click and select add.
  4. Again select all the converted polylines in '1' above and
You will have your self a surface. (see the snap shots below for directions)
HTH.
Ediriisa.
Message 3 of 9
KirkNoonan
You don't have to go through and connect all of the line segments. Just convert them all to polylines. Type pe and then hit m for multiple and window all of the lines and then choose to convert them to polylines. Then continue as Ediriisa recommended.
Message 4 of 9
AllenJessup
@KirkNoonan I thought you were right. But I tested it and the Join command works just as well.
Command: J
JOIN
Select source object or multiple objects to join at once: (My italics).
I had totally missed that until now.
Allen Jessup
CAD Manager - Designer
Message 5 of 9
Joe-Bouza
All great ideas. Not knowing where the line work came from I'd be inclined to MAPCLEAN to get to the end. One pseudo node and your'e baked
Joe Bouza
Message 6 of 9
Joe-Bouza
Now tie, overlap, double yada yada
Joe Bouza
Message 7 of 9
Joe-Bouza
Bow tie
Joe Bouza
Message 8 of 9
AllenJessup
MapClean is probably the best. I new from testing that Join worked on that drawing and that a good Surface would be created.
Allen Jessup
Message 9 of 9
neilyj666
Contours ( especially with a large interval) are probably the worst objects from which to build a surface but sometimes that's all you have. Remember to check all the option boxes when adding to a surface to minimise the flat spots etc that are inevitable when using contour objects.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
