Civil 3D Forum
Add pipe network labels to entire network default styles
5 REPLIES 5
528 Views, 5 Replies
Where can I find the out of box pipe label network default styles settings that the following commands use?
"ADDNETWORKPROFLABELS"
"ADDNETWORKPLANLABELS"
I would like to copy/change the default styles names to the styles I have created. This way it labels everything all at once using my styles.
These commands can be located on the ribbon under  "Pipes">>>"Add Network Labels"
2018 in use
Dave Z.
5 REPLIES 5
wfberry
Default labels for Pipe Network
Toolspace --> Settings --> Pipe Network --> Label Styles --> Select what you want
Bill
in reply to: wfberry
Yes I knew that is where the  pipes labels styles are. But what I am looking for is where the settings are for the group of labels styles the commands I listed earlier use. The individual styles are listed where you mentioned.
Obviously there are some preset styles the command uses. I want to change the names of those preset styles to the styles I have created.
Dave Z.
Ranjit_Singh2
Look under Commands under pipe network in toolspace settings tab
MMcCall402
Toolspace --> Settings --> Pipe Network -->(right click) Edit Feature Settings
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
That worked that you
Rail Community
