Civil 3D Forum
Latest Updates | New Knowledge Network Articles | Civil 3D
2 REPLIES 2
matthew.d
4548 Views, 2 Replies
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Civil 3D?
 Subscribe to receive updates for new Civil 3D Knowledge Network articles.
For additional updated solutions, also check out the Autodesk Blogs!
2016 Solutions 2017 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
2 REPLIES 2
matthew.d
in reply to: matthew.d
August 2018
Hydraflow Express gets “Invalid Installation. Program ending.” error
Where to download extensions for Civil 3D 2016
Inaccuracy during coordinate transformation in Civil 3D
Output animation video black in Storm and Sanitary Analysis
Peak Flows Greater than Expected in Hydraflow Hydrographs
Pickfirst not working in Civil 3D 2018
Export corridor as KML/KMZ from Civil 3D only shows wireframe in Google Earth
Points Disappear when Hatch Internal used
REHAB CORRIDOR icon is gone from the ribbon after duplicating the default Civil 3D workspace
Elevation Banding color appears to be inverted in Civil 3D
Rebuilding corridor regions in an existing intersection fails in Civil 3D
Cogo Points have become unselectable in Civil 3D
Cannot set point names when creating points from corridor
Civil 3D: Survey Data Coordinate System Not Working Correctly with Importing Points
Selection of points freezes Civil 3D
Hitting the esc key does not deselect an object in Civil 3D
Layers manager not functioning properly in Civil 3D
Flow stays the same when making changes in Hydraflow Hydrographs
Daylight Bench subassembly displaying as Layout Mode in Civil 3D
Adding pipe velocities to a Civil 3D pipe
Cannot trim objects with a sample line that has zero length in Civil 3D
Civil 3D: Running Hydraflow extensions do not print anything
Custom Rainfall Distribution Storm and Sanitary Analysis
Editing AutoCAD objects does not change surface definition in Civil 3D
Error: “Error opening surface” when trying to edit a surface in Civil 3D
Error: One or more of the secondary road profiles cannot be locked at this intersection in Civil 3D
Is it possible to add a pipe outside top in a profile view data band in Civil 3D
July 2018
Auto generate slope patterns for corridor in Civil 3D similar like MX Road
Chosen etransmit DWG version changes after quitting transmittal setup
Creating a grading infill does not work in Civil 3D
Error: “Unhandled Exception in Autodesk Civil 3D 2018 Language Pack - English” while opening certain...
Error: Not a valid geometry shape template when importing an Inventor file into the Infrastructure P...
Ignoring trees from surface and smooth the ground in Civil 3D
Xref’d Contour Lines do not plot correctly in Civil 3D 2018
Is it possible to replace an existing View Frames numbering in Civil 3D
Corridor Frequency Lines are still printed even if they are turned off in a Civil 3D drawing
Exporting an XML file with Cross Section data creates additional points in Civil 3D
Issue with pond volumes using Rational Method in Storm and Sanitary Analysis
Surface corridor modelling through cul-de-sac shows kink in Civil 3D
Unable to run analysis for 100-year storm event and get the nodes to display in Storm and sanitary a...
 Unable to apply superelevation for custom subassembly using Subassembly Composer (SAC)
Civil 3D freezes when exporting a surface to GeoTIFF
Error: “One or more subassembly .Net classes could not be found. Check Event Viewer for more informa...
Intersection corridor not daylighting properly to existing surface creating ​overlapping slope proje...
Is the Civil 3D 2018 “UKIE Country Kit” based on “Sewers for Adoption 7th Edition”
June 2018
Civil 3D: Program only runs when graphic driver is disabled
SaC: Point clouds will not display
Referencing out of the box Civil 3D template creates errors
AutoCAD Civil 3D: Adding breaklines to the surface creates bad surface
Civil 3D: Error: “Unable to run macro” error when running rules
Civil 3D: KNX_IMPORT Unknown command when running Geotechnical Module
Civil 3D: Layer manager does not load properly and is missing lots of information
Civil 3D: Surface showing up beyond existing ground surface in cross section views
Hydraflow Hydrographs Pond Outflow Increases
Recommended Specifications Civil 3D and InfraWorks
Resolving user specific issues by resetting AutoCAD Civil 3D 2019
Stationing Report for a profile does not show full stations
When screening is set to 1 in CTB file, plots created in Civil 3D 2019 not identical to 2017
SSA not working due to missing CAB files
Pipe hatch plots even when on a no-plot layer in Civil 3D
RMS kerb subassembly SF type in the AutoCAD Civil 3D 2018 Country Kits for Australia & New Zealand b...
Xref drawing Property Data Sets labels show as blank angled bracket entries “<>” in Civil 3D 2017
May 2018
Civil 3D: “One or more objects in this drawing cannot be saved…”
Civil 3D: Palette do not display correctly
Object enabler for Autocad civil 3D
System requirements for Autodesk Civil 3D 2019
Where is the service pack 4 for Civil 3D 2016
Autodesk Civil 3D: Default min gap between breaklines or 3DFace vertices for surfaces
Civil 3D: Program will crash with a fatal error when opening some files
Adding Shape code to custom Subassymbly from polyline crashes Civil 3D
AutoCAD: Line Type will not display
Civil 3D DWG cannot be opened, after a recover it cannot be saved or modified
Civil 3D: Cannot create a survey database. Error:“The survey database does not exist and could not b...
Civil 3D: Error: No function definition: CR_MNL
Civil 3D: Properties Palette Missing
Civil 3D: System crashing when using Object Viewer
April 2018
Split Point not being created when feature lines intersect
Civil 3D LandXML export for tin surface ignores boundary definition
Civil 3D_ It is not possible to save the workspace changes back to CUI when Bridge Modeller is loade...
Data References Surfaces Cause File Size to Grow
Data Shortcut Does Not Show Civil 3D Objects
Civil 3D: Prolonged open times after reinstall
Open file error when trying to open an stm file in Hydraflow Storm Sewers
Phantom Civil 3D objects appear in the drawing
Civi 3D is changing the elevation range for random section views
AutoCAD Civil 3D: Pipe network parts list not showing up during creation but shows up in Toolspace
Civil 3D 2017: Takes 10-15 minutes to open drawing after Windows updates
Civil 3D: Cut/Fill Report opens blank
Adding Custom Pipe Parameters to the Crossing Section and Profile Styles
System variable are not saved in AutoCAD
Civil 3D file cannot open
AutoCAD Civil 3D 2018 freezes or long delay when opening
Civil 3D: Cannot add points to the surface
Help links to generic help page instead of the specified topic’s help page
How to save performance with large surface shading in Civil 3D
Propert Set Data Do Not Migrate In Data Shortcuts in Civil 3D
River and Flood Analysis causes Civil 3D 2018 to freeze in Windows 10
Various displaying issues in Civil 3D
March 2018
Where to download AutoCAD Civil 3D Bridge Module 2018?
Pressure pipe fitting (Rotated Tee) on Profile View created from Data Shortcut looks skewed
Change to Australian Coordinate System for GDA2020
GIS import of Shape pipe network automatically creates null structures
AutoCAD Civil 3D: Superscript in point label styles
WMS taking to long zooming in and out
Error “CultureNotFoundException: Culture is not supported” when starting Subassembly Composer
Grip Edit at Cross Sections not working in River and Flood Analysis
In a Civil 3d Pipe Network the Null Structure cannot be used
Survey Database import of Survey LandXML file with feature attributes
When Importing Points Into Civil 3D, a Duplicate Point Message Appears
Civil 3D: Delays when selecting and releasing objects
Civil 3D: Unable to export a drawing
Error: “System error encountered during import” while importing IFC to Civil 3D or AutoCAD Architect...
Export to KML does not export properly in Google Earth
Point Groups highlight automatically on mouse-over
How to avoid creating interpolated triangles on the outer boundary in Surface creation
You want to know if there is a coordinate system available that encompasses all of George
AutoCAD Civil 3D: Create separate vertical profile tangent to another vertical profile
AutoCAD Civil 3D: Pressure Network Data References alert message
AutoCAD Civil 3D: Profile of secondary road created from Intersection Tool keeps breaking
Civil 3D: Reverts settings back to default instead of maintaining customer settings
How to get AutoCAD Civil 3D to display the gradient of a vertical profile curve at fixed increments
February 2018
User-defined property classification does not work for survey data
Civil 3D: Reports manager will not export to XSL or Open in Excel
Civil 3D: Sections move back to original position
Importing a REB KA40 alignment file into Civil 3D using the DACH Extension
AutoCAD Civil 3D has stopped working error due to OGSCertificationUtility-6_3.dll
Cannot build multiple corridor surfaces
Civil 3D 2018: Profile markers display outside split profile views
Civil 3D 2018: Reference Templates Settings revert to the default settings
Civil 3D hanging when clicking on objects
Civil 3D structure report error: Function ‘getStructType’ did not return a value
Civil 3D: When user chooses two feature lines in the same time, cursor disappears and program hangs
Disabled car park sign for Australia
In Civil 3D projected blocks are not displayed at the correct station in the profile view
Project Objects To Profile View Label Style
Random viewports containing point cloud data fail to plot from AutoCAD Civil 3D 2018
AutoCAD Civil 3D 2016 crashes at startup and gives an error message stating “AutoCAD has stopped wor...
Civil 3D: My on-line imagery is not showing
Civil 3D: Random Fatal Error while drawing was just sitting open
Corridor in Civil 3D does not create or display feature lines
Corridor surface overhang (horizontal offset) value
Missing band data on profile view for one point
Raster Design commands do not work in AutoCAD Civil 3D 2017
“Holes” in corridor surface due to overlap in the corridor
Assignment to Protected Symbol: c:ai_molc Enter Break Loop Keeps Popping Up In Civil 3D
Exported superelevation CSV file cannot be imported again
Qatar National Grid translation to WGS84 issue
Superelevation Profile Band Issue in Civil 3D
Cannot get Civil 3D to run
Civil 3D: Error: “Unhandled Exception e0434352 (e0434352h) at address 5d209d98h”
Custom Subassembly Incorrectly Importing into Civil 3D
Civil 3D: Viewport Freeze still Plots Frozen AEC Objects
Georeferenced image detected as 0,0,0 and not as per associated world file
Projecting To Multiple Cross-Sections with Feature Lines in Civil 3D 2018.1 and after
Unable to import Bentley Products into Civil 3D
January 2018
Civil 3D will not fully launch
Fatal error while running Autodesk AutoCAD Civil 3D 2017
Can’t open Survey Link DC 7.5.5 Help file
Civil 3D often crashes at random with a fatal error
Civil 3D: Combining Survey Points from multiple drawings
Civil 3D: Fatal Error on Drawing Save
Geotechnical Module 2018: GEOL.csv and HOLE.csv won’t load
Installing Autodesk Shared Reference Point for Civil 3D 2018 you get the error: “This extension requ...
Property Data Set Information to Objects in Civil 3D
Matt DiMichele
diana.yr
October 2018
Error: Failed to import data when importing IMX data into InfraWorks
How to create corridor from two parallel alignments with different profiles using a single assembly ...
When attaching an ECW file in Civil 3D the inserted image is blurry and pixelated
Error: A software problem has caused Autodesk Civil 3D 2019 - English to close unexpectedly
Grading tadpole symbol appears at 0,0,0 in Civil 3D
Pressure Part Catalog is blank in Civil 3D
Section view not displaying all links for an assembly in Civil 3D
Transition between regions of a corridor not smooth in Civil 3D
Civil 3D 2018 Customization file load failed
Cogo points are very big in the paper space although they display correctly in the model space in Ci...
Extracting labels from projected objects to a profile view directly to excel in Civil 3D
How to merge surfaces to one terrain in Civil 3D
Lane Slope Report in AutoCAD Civil 3D shows 0% values
Can’t edit survey database in Civil 3D
How to change styles to limit object visibility in Civil 3D?
Point labels from code set styles are missing in corridor section views in Civil 3D
Is it possible to add plans of different alignments on one sheet using the plan production tools in ...
Civil 3D is crashing when using Vestra Infravision plugin
Unable to import feature lines from Civil 3D to Infraworks
Corridor in not rebuilding correctly in Civil 3D when using custom subassembly
Subassembly not Hitting Marked Point in Corridor
Country-specific contents not available after installing Civil 3D Country Kit
Command Export to AutoCAD 2000 cannot be found in Civil 3D 2018 or 2019
Crash while running the HATCH command in Civil 3D
Imported points come rotated in custom Civil 3D template
Civil 3D opens up as AutoCAD when installed by the administrator account
Can Superelevation View be configured to label additional stations for runoff length in Civil 3D?
Crash while saving a drawing with referenced data shortcuts in Civil 3D
Context menu for point groups in Civil 3D German has two commands with the same name (Aktualisieren)
Cross hairs stutter across screen in Civil 3D 2019 after updating Windows 10 to 1803
Feature line with the exact same height of other feature line in Civil 3D
Profile PVIs cannot be moved in Civil 3D
Bearing labels are not correct when a single line is labeled in Civil 3D
Create Section Sheets wizard shows blank in Civil 3D
Error: “Unrecognized version and cannot be read” when opening the templates in Civil 3D
Pipe and Structure tables disregard sort values in Civil 3D 2018 and newer
Issues with one or more quadrant profiles being created in an intersection
While launching with a customized profile, Civil 3D displays the AutoCAD’s splash screen
Civil 3D throws error message written in Chinese
Minor Changes to Alignment in Intersection Delete PVI
Opening an InfraWorks intersection in Civil 3D does not show the intersection or roundabout built co...
Unhandled Access Violation error when trying to start Civil 3D as AutoCAD
How to assign a coordinate system to a Civil 3D DWG
Mismatch of units in Civil 3D - XY is in imperial and Z is meter
Corridor does not update after alignment has been extended in Civil 3D
Geotechnical module gives unknown command message in AutoCAD Civil 3D
PKT files for stock Civil 3D subassemblies
September 2018
Error: “Cannot use profile as vertical exaggeration is not 1.0” in Vehicle Tracking
Cannot use TopCon Magnet or Carlson Survey with Civil 3D 2019
Additional rail subassemblies included in the Civil 3D 2018.2 Update not available in 2019
What kind of information can be displayed for a pressure pipe on a profile view in Civil 3D?
Missing “Level of Detail” command on ribbon menu of Civil 3D 2019
Error: “File not found” when trying to attach the DWG files stored on macOS server in Civil 3D
Featurelines, alignments, profiles disappearing from saved drawings in Civil 3D
Sheet set manager not retaining DST file location
Computer unresponsive when using the OVERKILL command in AutoCAD Civil 3D
How to create a daylight with a variable slope and a fixed radius in Subassembly Composer
Cannot add Superelevation and Spiral data to “Alignment Curve Label” in Civil 3D
Catchment created in Civil 3D has areas lower then the defined discharge point
Civil 3D freezes while publishing to PDF from Sheet Set Manager
How to add custom Time of Concentration formula in Storm and Sanitary Analysis in Civil 3D
How to import point clouds in Civil 3D without using ReCap
Results from identical files not matching in Hydraflow Hydrographs in Civil 3D
A projected block is not displayed in a profile view in Civil 3D
Importing ISYBAU XML fails in civil 3D with the ISYBAU extension
Object Viewer shows additional color filling for a Surface in Conceptual, Realistic, Shaded, and Sha...
Cannot solve Vertical Curve error when importing LandXML profile into Civil 3D
Error: “Not a LandXML file. Please select another file.” when importing XML file in Civil 3D
Error: “The current coordinate system is not compatible with the model” while opening InfraWorks mod...
GIS Import in Storm and Sanitary Analysis doesn’t do anything
Animation video not created or is corrupted when recording in Storm and Sanitary Analysis
Data Shortcutted structures are rotated 90 degrees incorrectly in Civil 3D
Pipes use the layer the XREF is on for the lineweight and plot style when plotting in an xref in Civ...
Volumes Dashboard buttons do not display in Civil 3D 2018 on high resolution monitors
Diana Rouge
Social Media Specialist
Tags (1)
Rail Community
