Add contour to surface
Message 1 of 10
The brown line in the picture is the contour I wish to add to the surface. The yellow line is the contour of the surface after I added the contour. They do not match, especially in the acute angle of my contour. How to make them match? Thanks
Replies (9)
Message 2 of 10
user181
How did you add it to your surface? If you added it as a breakline you might want to add it as a contour instead.
Message 3 of 10
wfberry
Did you add it as a break line?
Bill
Message 4 of 10
no.
it is not a feature line. It is polyline. Should I convert it to feature line and then add as breakline? If this is the situation, why civil 3d has the function ADD Contour?
Message 5 of 10
wfberry
You do not have to convert it to a feature line to add it to the surface as a breakline.
Bill
Message 6 of 10
user181
Add as a contour (you can add a polyline as a contour to the surface)
Message 7 of 10
Thank you.
That is what I did. My question is why the computer generated contour do not exactly match the polyline I added as contour?
Message 8 of 10
ArchD
You may have to make some surface edits. Minimize flat areas works sometimes, other times you may have to swap edges.
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
Message 9 of 10
rkmcswain
@Anonymous - mainly because contours are a representation of a known surface. They are not source data from which to build a surface.
The following explains it somewhat: https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/...
Did you go through and understand all of the options when adding contour data?
Message 10 of 10
AllenJessup
You need to review the "About Weeding and Supplementing Factors for Contours" section in the second link in the post by @rkmcswain. I believe that the Middle Ordinate will be the key factor but Weeding and Supplementing should be checked also.
Allen Jessup
CAD Manager - Designer
