ACAD PROXY ENTITY
ACAD PROXY ENTITY
emersongonzalez1999
ACAD PROXY ENTITY
emersongonzalez1999
I was working on cross-sections for a project. Under the properties tab, before it said Section View, and now it became ACAD_PROXY_ENTITY and I lost the existing and proposed grades I had on the cross sections. Is there any way to have the grades reappear again?
ecfernandez
Hi @emersongonzalez1999, did you change C3D version along the process?
Have you tried to recover your drawing?
Camilo Fernández
P.Eng | Transportation
LinkedIn
emersongonzalez1999
No, I didn’t update to another version since I have the latest C3D 2024 Version. And the recovery file has the same error.
ecfernandez
Hi, that's too bad. I'm not sure, but your file might be corrupted. Try to do the following: select all the objects in your drawing, then create a WBLOCK, and then open a new C3D drawing with the default template, then paste the previously created block. Finally, explode the block, and you'll have all the elements of your previous drawing in a new file.
See if that helps. Best regards!
Camilo Fernández
LinkedIn
AllenJessup
Was the drawing round-tripped through vanila AutoCAD?
Allen Jessup
CAD Manager - Designer
