Civil 3D Forum
3d
3 REPLIES 3
196 Views, 3 Replies
3d
hello. i wanted tou create a solid form from specific points .i did by iserting the points into the programm with cvs file as a surface and ithouthg tha i was doing oit ok.in my computer its everything ok but when i send the fire (dwg)they see only points. some days know i try to do the commant for 3d prin but it doesent recognize it as a solid object.itried some soloution such us thiken,surfsculp,convtosolid or, convoto3dsolid but always fails .i trying for weaks and i dont now the programm very well and i must be ready for th unversity please help
 thank you
3 REPLIES 3
BrianHailey
Welcome to the forums!
If you are using Civil 3D 2015, you'll need to download and install Productivity Pack 1.
If you are using Civil 3D 2016, the command "Extract Solids from Surface" can be found by selecting the surface and then expanding out "Extract from Surface" on the "Surface Tools" panel.
If you are using something older then Civil 3D 2015 with Productivity Pack 1, you can try following THESE instructions.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
in reply to: BrianHailey
thank you so much for your reply but the problem is tha im using th 2014 version .could you please inform me if there is a solution ???????
troma
Did you read the second part of the link that Brian posted?
It shows the method there for earlier versions.
Mark Green
Working on Civil 3D in Canada
Rail Community
