3D Station Value Civil 3D profile
Beka_Tchigladze
Advisor Advisor
Beka_Tchigladze
hello all
I have such kind problem I want to show 3D Station value in profile band. likein this picture below and did not found way to do so please give me the advise how do I can solve the problem.
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
CivilFlow
Hello-
There isn't an easy way to get 3D or (Slope) stationing in Civil 3D.  There is a 3rd party app from Blue Sky Consulting
http://www.bsdconsultinginc.com/  that is used for pipeline projects that can do this very easily.  It's expensive though.
You could also do this with Station Equations, but it will require some sampling relative to your ground surface first, then some excel work.  The problem with that approach though is that your alignment will now have 3D stationing, which it in your case, may not be what you want.  Seems like you want both.   I guess you could have an alignment with normal 2D stationing  and one with station equations that calculate 3D stationing .  Then you could superimpose a 3D profile view band from this 2nd alignment under the 2D profile band as you show, but I concede this isn't clean.  Anyway, I hope this helps and good luck.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
