@Anonymous wrote:
Hi Tim,
Appreciate your time. I've attached a simplified drawing, There are a number of issues and it would be great if you could make comments on them. I've used Autocad but have never done anything like this before so its simply learning for me at this point.
1. As discussed, even though all surfaces should be white, they appear to be different colours
2. Isolines have been turned off but some lines are still very clear on the containers
3. The containers are exact replicas of each other which has made the drawing bulky and unresponsive. Is there a way to bunch all of the replicas together to reduce the drawing file size and the amount of RAM required to run it? I'm guessing there is a simple solution to this!
4. Ideally the end goal is to have a full design, and them use the location tab to georeference the drawing so I can place in in the location required. My problem is that the resolution of the inbuilt bing maps appears poor when I zoom in. I need this to be a 'professional' looking piece of artwork and right now I can't get it to look good. Any ideas?
Tadgh
To answer your questions:
1. This is because AutoCAD is applying shading to the faces in response to a its default light source. You can override this by adding your own lights where you want them. I'm not an expert in this, so anyone who is, please chime in. This might help: http://help.autodesk.com/view/CIV3D/2017/ENU/?guid=GUID-C865EEE9-DF5E-4BFF-87A7-1E8130F68AC6
2. Change your Face Style to Gooch. I think you will like the results better.
3. Not that I know of. If it were me and this was becoming a real problem, I would export a container as Autodesk FBX format, reference as a style in InfraWorks and then do my visualization there. If you are stuck with AutoCAD, maybe using Union to combine each container into a single 3D solid will help.
4. InfraWorks.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
