rendering error and wrong colouring
Hello. I'm having a number of difficulties in how my drawing is rendering. I've isolines turned off, and the I've selected white in properties to be the colour of all the objects for now, but something appears to be preventing the white from coming through. Also, as you see from the attached image a number of lines remain even though isolines are turned off.. Any ideas how I could solve this problem or what could be causing it?
Ideally, I want the shipping containers to be white, and not grey.
Tadgh
Eduardo.Soethe
Hi @Anonymous
You can learn more about render on AutoCAD following this link
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-Core/files/GUID-94CF8D57-8844-495B-AD85-003D1C32B406-htm.html
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
