Civil 3D Forum
2023 | New Knowledge Support Articles | AutoCAD Civil 3D
8 REPLIES 8
Message 1 of 9
lim.wendy
1629 Views, 8 Replies
Scroll below to view Autodesk Knowledge Network support solutions that were created in 2023.
Looking for older articles? They're posted below:
2022 | New Knowledge Support Articles | AutoCAD Civil 3D
2021 | New Knowledge Support Articles | AutoCAD Civil 3D
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Labels (2)
8 REPLIES 8
Message 2 of 9
lim.wendy
in reply to: lim.wendy
Jan 2023
Published Date
Summary
Knowledge Article
31-Jan-23
Mark Point is not added to the corridor's surface definition in Civil 3D.
How to add Mark Point to corridor's surface definition in Civil 3D?
31-Jan-23
The band labels don't react to the selections in the Section View band tab
It is not possible to switch on or off the Label Start/End Offset in the section view of Civil 3D
25-Jan-23
Is it possible to display Section Views not perpendicular to the alignment in Civil 3D?
24-Jan-23
Neenah Foundry inlets show "nan" in Analysis Summary in Storm and Sanitary Analysis for Civil 3D
23-Jan-23
How to prevent the default styles of being changed automatically in Civil 3D
23-Jan-23
Sufrace tab is missing in the OKSTRA assignment
When trying to assign OKSTRA data with the Civil 3D DACH Country Kit OKSTRA tools, the tab for surfa...
19-Jan-23
How to edit Profile Data Band labels in Civil 3D
19-Jan-23
How to set a Civil 3D label text height to resize differently based on the viewport scale value.
How to set label text height at different scale in Civil 3D
18-Jan-23
Labels disappear while working in a drawing after updating Civil 3D
16-Jan-23
Cannot create corridor transitions based on the Offset Assembly in Civil 3D.
13-Jan-23
Cannot define a bypass link for On Sag inlet in Storm and Sanitary Analysis for Civil 3D
11-Jan-23
TIN Surface does not transform successfully or does not maintain the correct surface definition using the Coordinates Transformation Extension in Civil 3D. Survey query definitions for Points and Figures (breaklines)  are not transformed.
TIN Surface does not transform using the Coordinates Transformation Extension in Civil 3D
11-Jan-23
Unable to zoom in on or grip edit a line in Civil 3D or AutoCAD
10-Jan-23
Delete the pay item data in a DWG or DWT.
How to permanently remove the pay item information from a DWG in Civil 3D
2-Jan-23
When Civil 3D UKIE is opened, the notification about program configuration is displayed.
"Please wait while Windows configures Autodesk Civil 3D Country kit" when opening Civil 3D
Wendy Lim
Rails Summit
Message 3 of 9
lim.wendy
Feb 2023
Published Date
Summary
Knowledge Article
27-Feb-23
New pipes and structures of the DACH Country Kit are missing in the Parts Builder.
After the installation of the DACH Country Kit, gravity pipe content is missing
24-Feb-23
When working with Collaboration for Civil 3D, editing a host drawing will update its external references (XREFs) file versions in ACC Autodesk Docs or BIM 360 without opening or editing the XREF file itself.
XREF file version is updated in ACC when working with Collaboration for Civil 3D
23-Feb-23
Is it possible to divide levels in a subassembly in Civil 3D?
Divide levels of subassemblies in Civil 3D
22-Feb-23
Can older AutoCAD product installations be deleted before installing a new release of an AutoCAD product?
Can older AutoCAD product installations be deleted before installing a new release of an AutoCAD pro...
21-Feb-23
"The code execution cannot proceed because MSVCR120.dll was not found..." when starting Civil 3D
"The code execution cannot proceed because MSVCR100.dll was not found..." when starting Civil 3D
20-Feb-23
Is it possible to turn off the refresh or regen of all elements on a pressure pipe profile view in Civil 3D?
Is it possible to turn off the refresh or regen of all elements of a pressure pipe in profile view i...
18-Feb-23
"Error 313: Cannot open scratch rainfall interface file..." appears when running a model in Storm and Sanitary Analysis for Civil 3D.
"Error 313: Cannot open scratch rainfall interface file..." in Storm and Sanitary Analysis for Civil...
14-Feb-23
Hydrograph hits an upper limit of hours and stops running in Hydraflow Hydrographs Extension for Civil 3D
Hydrograph hits an upper limit of hours and stops running in Hydraflow Hydrographs Extension for Civ...
11-Feb-23
Cannot turn off the pop up to specify a replacement for SHX files in Civil 3D.
11-Feb-23
Pump removes all water before upstream basin is used in Storm and Sanitary Analysis for Civil 3D
10-Feb-23
How to get Arabic Language Pack and fonts in Civil 3D
10-Feb-23
Is there a recovery tool for Civil 3D
9-Feb-23
When clicking the gear icon in the Blocks palette for Block Sync Settings, a dialog appears which states File Not Found.
Block Sync Settings button brings up a File Not Found dialog in AutoCAD 2023
8-Feb-23
Cannot locate saved workspace and profile files for Civil 3D
1-Feb-23
Civil 3D labels display with an offset or gap when viewed in Autodesk Docs with any web browser.
Civil 3D label display incorrectly in Autodesk Docs
1-Feb-23
Is it possible to create subfolders for Vault References in Civil 3D?
How to create subfolders for Vault References in Civil 3D?
Wendy Lim
Rails Summit
Message 4 of 9
lim.wendy
March 2023
Published Date
Summary
Knowledge Article
29-Mar-23
Transparent commands don't work properly in AutoCAD script file. You are unable to exit or escape the transparent command to return to running command when running a routine through an SCR file
Unable to exit transparent command from script file in Civil 3D
28-Mar-23
How to convert a straight pipe to a curve pipe in plan view in the middle of a pipe run without detaching the pipe run?
How to convert straight pressure pipe to curve in Civil 3D
27-Mar-23
The Volume dashboard is not displaying properly in Civil 3D.
The volume dashboard panel is not properly displaying in Civil 3D
25-Mar-23
Diverted Hydrographs show the same flow for each diversion in Hydraflow Hydrographs for Civil 3D
22-Mar-23
Civil 3D crashes wiht Fatal error and CER when accesing the properties of a return curb alignement
Civil 3D crashes with Fatal error and CER when accessing the properties of a return curb alignment
21-Mar-23
Crash with Fatal Error when trying to plot a corridor in Civil 3D
17-Mar-23
Custom dashed linetype with text shows as continuous line in AutoCAD products
16-Mar-23
Are Cloud Storage drives supported or recommended for Civil 3D workflows?
Does Civil 3D support Cloud Storage Drives?
14-Mar-23
The Panorama Event Vista displays "Baseline is not published yet, please try to fix the corridor..." when attempting to data reference, repair a broken reference or synchronize and existing corridor Data Shortcuts in a Civil 3D drawing.
"Baseline is not published yet..." when synchronizing Corridor Data Shortcuts in Civil 3D
10-Mar-23
Xrefs content cut off on part of the screen in Civil 3D
Content of External References not displayed on part of the screen in Civil 3D drawing
8-Mar-23
Dynamo for Civil 3D running but not working
All nodes show Null value after running script in Dynamo for Civil 3D
8-Mar-23
Is it possible to load or export OKSTRA data in Civil 3D?
To export or import a CTE OKSTRA file format in Civil 3D
7-Mar-23
When inserting JP2 image AutoCAD crashes
Insert JP2 Image File causes crash in AutoCAD Products
7-Mar-23
Label styles are not updating to settings used in Referenced Template in Civil 3D
4-Mar-23
Pressure Network Pipe, Fitting and Appurtenance part name and description edits in source drawing do not update or synchronize with data shortcut in host drawing.
Pressure part name does not update from data shortcut in Civil 3D
3-Mar-23
Cardinal directions are rotated independently from ViewCube in Civil 3D
3-Mar-23
Where is the database of the Geotechnical Modeler in Civil 3D located and can it be changed?
Path of the database of the Geotechnical Modeler in Civil 3D
3-Mar-23
How to display pipe structures with a mask to the pipes in the Civil 3D profile view
Structures in Profile View aren't masking the pipes in Civil 3D
2-Mar-23
Junction Loss (Hj) is zero in Analyze Gravity Network results even though a Junction Loss has been entered for the pipe in Civil 3D
Junction Loss (Hj) is zero in Analyze Gravity Network results even though a Junction Loss has been e...
Wendy Lim
Rails Summit
Message 5 of 9
lim.wendy
April 2023
Published Date
Summary
Knowledge Article
28-Apr-23
ANZ pipes and structures do not display in network layout tools in Civil 3D with Country Kit installed.
Country Kit pipes and structures not available in a drawing created from a custom template in Civil ...
27-Apr-23
Profile view is rotated when plotting to PDF in Civil 3D
26-Apr-23
Is modeling a detention pond with an outfall restrictor supported in Hydraflow Hydrographs for Civil 3D?
Is modeling a detention pond with an outfall restrictor supported in Hydraflow Hydrographs for Civil...
25-Apr-23
The cross slope value for Connected Profile is not correctly maintained when creating Connected Alignment in Civil 3D.
Cross slope value for Connected Profile is not correctly maintained when creating Connected Alignmen...
25-Apr-23
In Windows File Explorer, double-clicking to open an existing DWG opens new drawing from template "Drawing1" and the subject drawing in AutoCAD Products
Double-click to open DWG opens new "Drawing1" in AutoCAD Products
21-Apr-23
The IFC 4x3 Extension does not work in Civil 3D.
20-Apr-23
How to select all objects on the active layer in AutoCAD
18-Apr-23
The switch function in Subassembly Composer for Civil 3D displays the wrong geometry when a specific Case is used.
Switch function in Subassembly Composer for Civil 3D displays wrong geometry when a specific Case is...
17-Apr-23
Custom Install is not installing Dynamo for Civil 3D 2022.2.1
12-Apr-23
Is Grading Optimization available for Civil 3D 2024?
12-Apr-23
Is it possible to maintain end station number after making changes to an alignment in Civil 3D
11-Apr-23
Is it possible to create a corridor from multiple feature lines in Civil 3D?
8-Apr-23
Property Set does not export to FGDB or ArcGIS Online from Civil 3D
Property Set does not export to ArcGIS in Civil 3D
7-Apr-23
"FATAL ERROR: Unhandled ... Exception..." when deleting data band labels from profile view in Civil ...
6-Apr-23
Where to set default sheet set for Plan Production Tools in Civil 3D
4-Apr-23
Transparencies or image fade settings do not plot correctly after updating Civil 3D
3-Apr-23
The custom turnout is missing when trying to add a turnout in Civil 3D.
A custom turnout is not listed in the turnout catalog and cannot be added from the Civil 3D ribbon
1-Apr-23
Pond Elevation drops below Wet Pond Elevation in Elevation vs Time graph in Hydraflow Hydrographs for Civil 3D
Pond Elevation drops below Wet Pond Elevation in Elevation vs Time graph in Hydraflow Hydrographs fo...
Wendy Lim
Rails Summit
Message 6 of 9
lim.wendy
May 2023
Published Date
Summary
Knowledge Article
27-May-23
Is it possible to convert block attributes to object data in Civil 3D?
How to convert block attributes to object data in Civil 3D
26-May-23
Error: "Type mismatch" when creating a point group with elevation filter for Cogo Points in Civil 3D
25-May-23
Cannot extract 3D Solids between two surfaces in Civil 3D with error code 18030 displayed, and the difference is not calculated.
Cannot extract 3D Solids between two surfaces with error code 83027 in Civil 3D
24-May-23
Not possible to import ALKIS/NAS data for the "Grunderwerb" function of the Civil 3D DACH Country Kit
Not possible to import ALKIS/NAS data for the "Grunderwerb" function of the Civil 3D DACH Country Ki...
16-May-23
How to create a vehicle tracking swept path for roundabouts.
How to create a vehicle swept path for roundabouts in Civil 3D Vehicle Tracking
16-May-23
Viewport transparency not working for surface contours in Civil 3D
15-May-23
Error: “Unknown command “PYTHON”” when trying to run Python from the Civil 3D command line
15-May-23
Freeze with the Edit Pipe Network in Storm an Sanitary Analysis (SSA) command in Civil 3D
Freeze with Edit Pipe Network in SSA command in Civil 3D
12-May-23
Is it possible to use the Autodesk Batch Save Utility with Windows Standard User permission (not Run as Administrator)?
Unable to run Batch Save Utility with no Admin rights in Civil 3D
10-May-23
When opening any drawing in AutoCAD Map 3D or Civil 3D, a maperrorlog.xml file is created
maperrorlog.xml is created in AutoCAD Map 3D and Civil 3D
05-May-23
Import LandXML file for pipe networks and automatically adjust pipe catalogs in Civi 3D
Import LandXML file for pipe networks and automatically adjust pipe catalogs in Civil 3D
03-May-23
Graphics appear pixelated in Civil 3D. Components such as the navigation cube may not display as expected.
Pixelated display in Civil 3D
02-May-23
How to change the Layers for features created by the Geotechnical Modeler of Civil 3D
02-May-23
How to change the point styles for boreholes in the Geotechnical Modeler of Civil 3D.
02-May-23
How to compare two Points in Civil 3D?
Is it possible to compare two Points in Civil 3D?
02-May-23
Is it possible to display triangles indicators for Feature Lines in isometric view in Civil 3D?
02-May-23
When executing Reports to export data in Excel format from Toolspace > Toolbox > Reports Manager in Civil 3D. The report fails to save in XSL format and will not launch Microsoft Excel.
Report manager does not export to Excel in Civil 3D
Wendy Lim
Rails Summit
Message 7 of 9
lim.wendy
June 2023
Published Date
Summary
Knowledge Article
29-Jun-23
How to have more styles for points in Civil 3D to have more symbols available?
29-Jun-23
How to import survey data to Civil 3D to display styles according to codes
How to import Survey data to Civil 3D display styles depending on codes
28-Jun-23
"No LandXML compatible objects found" when exporting LandXML file from drawing in Civil 3D
27-Jun-23
The default ribbon Pressure Network Creation Tools command creates path-based pipe run; how to design Part based pressure network by layout.
Where is part based not pipe run pressure network in Civil 3D
26-Jun-23
Where to download the Autodesk Standardized Data Tool
Download the Autodesk Standardized Data Tool
22-Jun-23
How to start Civil 3D with a default custom profile
22-Jun-23
The raster DEM of an ESRI ASC ASCII surface has the wrong raster size in Civil 3D
19-Jun-23
Drawing objects are located outside the borders of the coordinate system
No Bing Map is data displayed for the area of interest in Civil 3D or Map 3D
12-Jun-23
When adding masking to existing alignment in Civil 3D, program may freeze for a few minutes.
Civil 3D freezes when adding masking to alignment
07-Jun-23
When adding any Boundary type to a Civil 3D Surface, "A closed boundary cannot be determined" error message is displayed.
"A closed boundary cannot be determined" when adding a surface boundary in Civil 3D
07-Jun-23
When using the Inventor-based Generic Drainage Pipe Catalogs in Civil 3D, Pipe Network structure has no 3d shape.
Generic Drainage structures have no 3D shape in Civil 3D
02-Jun-23
In Spanish Civil 3D, the MAP CLEAN UP window displays incomplete content.
Drawing Cleanup dialog window is displayed incomplete in Civil 3D
01-Jun-23
When creating an Autodesk Inventor based Pipe Network Catalog using the Infrastructure Parts Editor (IPE), where is the default publish location for the shape template IPT files consumed in Civil 3D.
What is the Inventor Template location when publishing from IPE in Civil 3D
Wendy Lim
Rails Summit
Message 8 of 9
lim.wendy
July 2023
Published Date
Summary
Knowledge Article
31-Jul-23
"** Undefined Shape [Number]" when copying MText from of DWG to another DWG in Civil 3D
26-Jul-23
In Storm and Sanitary Analysis (SSA), you would like to make subbasins (sub-catchments) displayed with different colors.
How to change subbassin color in SSA Civil 3D
25-Jul-23
Where to download Civil 3D extensions
How to download Civil 3D extensions
13-Jul-23
When modelling a gravity Pipe Network, pipes only connect to the center or insertion point of the structure (manhole, catch basin, etc.); how to use Pipe Network structure connection points?
How to use Pipe Network connection points in Civil 3D
04-Jul-23
Where to find the coordinate systems for China CGCS2000
Wendy Lim
Rails Summit
Message 9 of 9
lim.wendy
August 2023
Published Date
Summary
Knowledge Article
29-Aug-23
When using the BIND command to bind external reference (Xref) drawing using either the bind or insert options in a host drawing the Civil 3D Note Labels revert back to generic text content and text overrides are removed.
Bind resets note labels to default in Civil 3D
22-Aug-23
Labels change direction when rotated 110 degrees in Label Style Composer in Civil 3D
22-Aug-23
Surface import of LandXML file shows an empty dialog or no surface is imported in Civil 3D
09-Aug-23
When opening an Autodesk Docs drawing with associated Sheet Set, the Sheet Set for Web and Legacy Sheet Set Palette both open in AutoCAD products. The Sheet Set DST file becomes unreliable, edit may not save, and DST is inadvertently locked or unlocked incorrectly.
Sheet Set Manager for Web is unstable in AutoCAD Products
02-Aug-23
The background mask for pressure pipe label is too big for the text and extends too far in Civil 3D
Background mask of pressure network labels extends too far in Civil 3D
02-Aug-23
Error: "eNotOpenForWrite" with Coordinate Transformation in Civil 3D
Wendy Lim
Rails Summit
Rail Community
