After updating to Civil3D 2018.2, the PVI and PVC-PVT symbols for the profile do not get clipped at the extents of the profile view. If the drawing is opened with the Civil3D 2018.1 update installed, everything is fine.
After installing the Civil3D 2018.2 update, you can see the PI symbols displaying outside the split view located at station 718+00 rather than being clipped at the profile view extent.
Has anyone else experienced this?
Solved by rgtdg. Go to Solution.
This looks like the same issue that was posted about last month (with no solution to date). https://forums.autodesk.com/t5/autocad-civil-3d-forum/pvi-markers-showing-up-outside-the-profile-vie...
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Pronouns: She/Her
I’ve just posted in the thread that @KMercier_C3D posted. Same applies here. I will try and raise with Civil3D dev team this week as I’m with them all week
Thank you both for your assistance. Looks like we'll be stepping back to an earlier update for now.
I was able to replicate the behaviour in 2018.2. I'm with @dsimeone right now, he's aware and will keep us updated on a fix
I have the same issue. See my screencast link.
There is now a beta fix for this issue in the Autodesk Beta forum. On customer test so far and I will Test when back in the UK next week.
Once tested By a few people it will be released. Thanks to @dsimeone and @TimYarris for speeding this through
Any further information on a hotfix or update to resolve this problem?
Have asked dev team for update on general release of fix
So is this ever going to get fixed? Have yet to see a patch for it.
I find it unbelievable that this still wasn't fixed with the recent 2018.3 Update.
There is a fix located at http://help.autodesk.com/view/CIV3D/2018/ENU/index.html?caas=caas%2Fsfdcarticles%2Fsfdcarticles%2FMa...
Hope this helps!
Hope this helps!
Thanks. Much appreciated.
