2015 feature line edit
randyspear6624
randyspear6624
I'm stuck in feature line grade edit... it won't accept any end point and it won't cancel out of the command.
Is there a fix for this?
AllenJessup
I hadn't noticed that problem. What SP version are you at?
Allen
Allen Jessup
CAD Manager - Designer
randyspear6624
I'm on SP3.
AllenJessup
Same here. Can you post a drawing with a couple of the Featurelines you're having trouble with. Also - Your getting stuck in the Grading Elevation Editor tab of the Panorama, correct?
Allen
Allen Jessup
randyspear6624
I think I figured it out... I've got a parking lot with some elaborate grading (which isn't my forte). I've got a ridiculous amount of feature lines very tight together to model it accurately. Grading tools don't seem to triangulate correctly so i'm sticking with basic feature lines. Anyways I had two feature lines with the same start point so I was unknowingly editing the wrong one I think and it kept saying invalid PI.
It still doesn't explain why I couldn't escape out of the command though... neither quit of close would work. I had to end task it.
