2014 C3D upgrade to ?????
This widget could not be displayed.
I'm currently working on 2 projects using C2D 2014. I would like to upgrade to take advantage of new features. Any advice on hoe far to go - 2015, 2916, 2017?  I realize the higher I go the features are available but I'm also interested in downward compatibility with my drafting sub who is stuck at 2010 ACAD.
rl_jackson
2017 is not compatible with any prior version without a lot of additional work, and I suspect that the 2018 release (end of April if all goes according to prior years) is basically going to be the same thing.
2013-16 were compatible drawing formats. 2013 & 14 templates are not compatible with each other due to SQL changes.
I would recommend that your sub, upgrade during the process. 2010 is a prior format, and will just make additional work for you.
Rick Jackson
Survey CAD Technician VI
jrauch
If you're using Civil 3D 2014, and your drafting sub is using AutoCAD 2010, then you're already having to convert the drawing, right? It's just a Save As or eTransmit once you get the Civil 3D objects out of the picture. And from my experience, the ExportC3DDrawing command has only gotten better with time. So the latest version you're comfortable with (2017 has been out for almost a year) would likely yield the best results. Good luck!
-John J. Rauch, P.E.
Cadguru42
You could upgrade to 2016 without hardly any issues related to how you're currently working. However, going to 2017 will cause  you headaches as it's not backwards compatible. Since you are working with someone on 2010, you have to already be downgrading  your drawing, so it might not be a big issue for you to go on to 2017. Personally I'd move to 2016 and then stick with that for the remainder of your current projects.
C3D 2022-2025
Windows 11
32GB RAM
Thank you both for your comments.
