Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Retrieve all objects from the "Applies to" tab in C#
4 REPLIES 4
melanie_ernstLF68Z
273 Views, 4 Replies
Hello!
Is there any way to retrieve all the objects that are listed in the "Applies to" tab, where the property sets can be defined?
I tried to do it in C#, but I just could not figure out where they are stored...
In the image below I have marked the elements I am talking about.
Thanks in advance!
4 REPLIES 4
I am curious about this shared function from the PropertyDataServices. It appears to provide what you are describing.
Dim names() As String = PropertyDataServices.FindEligibleClassNames()
Thanks @hippe013 , this is somewhat what I was looking for! Is there a way to retrieve the class of the classname? because my Civil3D is in german, so I want to get the german names/display names as well and this function returns me a list, but all the entries also include the aec/aecmap, etc prefixes
I am not certain as to how to retrieve the localized (German) class names. However, the list of classes that are returned from the FindEligibleClassNames function are the C++ classes. I am not even certain as to how to retrieve the displayed name as shown in the AppliesTo tab, but retrieving the runtime Type gets us a little closer to a solution. You can use the SystemObjects.ClassDictionary to retrieve the RxClass of each C++ class in the returned list. Then using the RxClass you can get the Runtime Type. I was able to return the Runtime Type of each of the C++ Classes except for one. Trying to get the runtime type of the DMLEGEND (dxf name) gave me a System.AccessViolationException so I exclude that one.
In the following example I am building a list of classes for display in a window. I have a custom class ClassNameModel to hold the various names. The ClassNameModel has three properties, the class name (C++), the DXF Name, and the Runtime Type Name. Note how I skip over the "DMLEGEND" class.
Dim dxf As String
Dim runtimeTypeName As String
Dim dict = SystemObjects.ClassDictionary
For Each name As String In names
   Dim rxc As RXClass = dict.Item(name)
   dxf = rxc.DxfName
   If dxf = "DMLEGEND" Then
      runtimeTypeName = "<<< AccessViolationException >>>"
   Else
      Dim tp As Type = rxc.GetRuntimeType
      runtimeTypeName = tp.Name
   _classes.Add(New ClassNameModel(name, dxf, runtimeTypeName))
Next
I hope that this helps!
Thanks @hippe013 !
I have converted it to C# code and created a list with all the RXClass names:
List<string> rxClassNames = new List<string>();
var dict = SystemObjects.ClassDictionary;
string[] eligibleClassNames = PropertyDataServices.FindEligibleClassNames();
foreach (string className in eligibleClassNames)
    if (dict.Contains(className))
        RXClass cl = (RXClass) dict[className];
        rxClassNames.Add(cl.DxfName);
 I am now trying to retrieve the display names… If I find something/figure it out, I'll post it here
Rail Community
