Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
I want to export text boxes to a comma delimited file
4 REPLIES 4
700 Views, 4 Replies
My end goal is to pair 2 sets of data together based on the proximity of their lat and long. To do that I need to figure out how to export a layer of text boxes to PNEZD; which I can then run thru excel to match the data.
Is it possible to export text boxes with lat and long data?
Labels (3)
4 REPLIES 4
Jeff_M
Jeff_M
What is a Text Box? Can you post an example dwg?
in reply to: Jeff_M
The red X and text are my COGO points and the purple text is a multi-line annotation "textbox"
My end goal is to take the purple text and input it into the name box for each point based on proximity. So that every purple name is input into the closest red cogo point.
in reply to: Jeff_M
Thank you for your help @Jeff_M I ended up figuring it out this morning at work. The Extract Data command on the Insert ribbon allowed me to export the Value (text) and the easting/northing that will allow me to combine the data with my closest COGO points.
Jeff_M
Jeff_M
Glad you got that figured out. Sorry I wasn't able to come back to this until now.
Rail Community
