Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
How to insert the table for these cogopoints created
7 REPLIES 7
Message 1 of 8
goswami12897
370 Views, 7 Replies
Hello I want to insert the table for the cogopoints created on each alignment separately how to do it?
    public class InsertPointsSop
        [CommandMethod("InsertSOP")]
        public void Insert()
            Document document = Application.DocumentManager.MdiActiveDocument;
            Database database = document.Database;
            Editor editor = document.Editor;
            editor.WriteMessage("\n Select Alignments");
            PromptSelectionResult blockSelected = editor.GetSelection();
            if (blockSelected.Status != PromptStatus.OK)
                editor.WriteMessage("\n Selected wrong Objects. Please restart the command to try again");
                return;
            PromptDoubleOptions intervalInput = new PromptDoubleOptions("\nEnter the interval of stations")
                AllowNegative = false,
                AllowNone = false,
                AllowZero = false,
            PromptDoubleResult intervals = editor.GetDouble(intervalInput);
            if (intervals.Status != PromptStatus.OK)
                editor.WriteMessage("\n Wrong Input");
                return;
            SelectionSet set = blockSelected.Value;
            using (Transaction transaction = database.TransactionManager.StartTransaction())
                CivilDocument cDoc = CivilApplication.ActiveDocument;
                CogoPointCollection cogoPoints = cDoc.CogoPoints;
                foreach (SelectedObject obj in set)
                    if (obj.ObjectId.ObjectClass.IsDerivedFrom(RXObject.GetClass(typeof(Alignment))))
                        Alignment str = transaction.GetObject(obj.ObjectId, OpenMode.ForRead) as Alignment;
                        for (double j = 0; j < str.Length; j += intervals.Value)
                            Point3d point3D = str.GetPointAtDist(j);
                            ObjectId cgp = cogoPoints.Add(point3D, true);
                            CogoPoint cogoPoint = cgp.GetObject(OpenMode.ForWrite) as CogoPoint;
                            string modifiedName = $"Level : {str.Name}-{j}";
                            cogoPoint.PointName = modifiedName;
                transaction.Commit();
7 REPLIES 7
Message 2 of 8
hosneyalaa
in reply to: goswami12897
This line  , i think not working in civil 2016 and above , check :heavy_check_mark:
Message 3 of 8
goswami12897
in reply to: hosneyalaa
points are inserted successfully
Message 4 of 8
hosneyalaa
I am sorry, you are right
Message 5 of 8
Jeff_M
@goswami12897 the current API does not provide a method for adding PointTables. To help make it easier after creating the points, I would create a PointGroup for each alignment and add the created points to the associated group. That way the user can use the normal Create Table command and select the point group for the table.
Message 6 of 8
goswami12897
in reply to: Jeff_M
how can I create groups for each individual alignments cogopoints please help
Message 7 of 8
Jeff_M
@goswami12897 here is your code with the points added to a new point group with the same name as the alignment:
            PromptSelectionOptions promptSelectionOptions = new PromptSelectionOptions();
            promptSelectionOptions.MessageForAdding = "\n Select Alignments";
            SelectionFilter ssFilter = new SelectionFilter(new TypedValue[] { new TypedValue(0, "AECC_ALIGNMENT") });
            PromptSelectionResult blockSelected = editor.GetSelection(promptSelectionOptions, ssFilter);
                return;
                AllowNone = false,
                AllowZero = false,
                return;
                    var points = new List<uint>();
                        points.Add(cogoPoint.PointNumber);
                    if (points.Count > 0)
                        var ptGroupId = cDoc.PointGroups.Add(str.Name);
                        var ptGroup = (PointGroup)transaction.GetObject(ptGroupId, OpenMode.ForWrite);
                        var query = (StandardPointGroupQuery)ptGroup.GetQuery();
                        query.IncludeNumbers = getIncludeList(points);
                        ptGroup.SetQuery(query);
        private string getIncludeList(List<uint> points)
            uint[] ptNums = points.ToArray();
            string pointList = "";
            if (ptNums.GetLength(0) == 1)
                pointList = ptNums[0].ToString();
            if (ptNums.GetLength(0) > 1)
                uint i = 0;
                uint startRange;
                int lastIndex = ptNums.GetLength(0) - 1;
                while (i <= lastIndex)
                    startRange = ptNums[i];
                    while ((i < lastIndex) && (ptNums[i + 1] - ptNums[i] == 1))
                        ++i;
                    pointList += rangeBetweenNumbers(startRange, ptNums[i]);
                    if (i++ < lastIndex)
                        pointList += ",";
            return pointList;
        private string rangeBetweenNumbers(uint startNum, uint endNum)
            uint diff = endNum - startNum;
            if (diff == 0)
                return startNum.ToString();
            if (diff > 0)
                return startNum.ToString() + "-" + endNum.ToString();
            return "";
Message 8 of 8
goswami12897
in reply to: Jeff_M
Thanks a lot
Rail Community
