Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Extract ground points section to model or file like land does.
25 REPLIES 25
Message 1 of 26
e_omairquliey
1207 Views, 25 Replies
Hallo guys i have problem that i can't extract the ground points section from civil 3d , i have searched the report section a lot of times and i couldn't extract them to model or file like land help me...
25 REPLIES 25
Message 21 of 26
TerryDotson
in reply to: e_omairquliey
i need to extract the ground points which view in sample sections every 25 meters.
Try the attached points (DWG & XLSx files).
Message 22 of 26
I do know that order from future line but it's very difficult to arrange it in Excel.
as well as some stations there is no 0m offset for them.
I hope Autodesk solve this issue soon.
Message 23 of 26
e_omairquliey
in reply to: TerryDotson
I am v thankful for your help .
I will check the points with the ground section and i will back to tell you if they are correct.
Message 24 of 26
hosneyalaa
Maybe
Use this code And arrange it as you like
https://forums.autodesk.com/t5/civil-3d-customization/get-section-points-problem/m-p/6000784
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using aGi = Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil.ApplicationServices;
using Autodesk.Civil.DatabaseServices;
using CivDb = Autodesk.Civil.DatabaseServices;
namespace Extensions_Section
    public class Extensions_Section
        [CommandMethod("testExtensions_Section")]
        public void stExtensions_SectiondA()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            CivilDocument civdoc = CivilApplication.ActiveDocument;
            Editor ed = doc.Editor;
            PromptEntityOptions entOpts = new PromptEntityOptions("Select section:");
            entOpts.SetRejectMessage("...not a section, try again.");
            entOpts.AddAllowedClass(typeof(CivDb.Section), true);
            PromptEntityResult entRes = ed.GetEntity(entOpts);
            if (entRes.Status != PromptStatus.OK)
                return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                CivDb.Section sec = (CivDb.Section)entRes.ObjectId.GetObject(OpenMode.ForRead);
                var LL = sec.GetSectionLinks();
                var LLPOINT = sec.GetValidSectionPoints();
                tr.Commit();
    public static class ExtensionsSection
        public static IEnumerable<SectionPoint> GetValidSectionPoints(this CivDb.Section section)
            var valid = new HashSet<Point3d>();
            dynamic comSec = section.AcadObject; // AeccSection
            dynamic comLinks = comSec.Links; // AeccSectionLinks
            for (int i = 0; i < comLinks.Count; i++)
                dynamic comLink = comLinks.Item(i); // AeccSectionLink
                if (comLink.Type != 1)
                    valid.Add(new Point3d(comLink.StartPointX, comLink.StartPointY, comLink.StartPointZ));
                    valid.Add(new Point3d(comLink.EndPointX, comLink.EndPointY, comLink.EndPointZ));
            return (from sp in section.SectionPoints
                    where valid.Contains(sp.Location)
                    select sp);
        public static IEnumerable<Section.SectionLink> GetSectionLinks(this CivDb.Section section)
                var start = (from sp in section.SectionPoints
                             where sp.Location.IsEqualTo(new Point3d(comLink.StartPointX, comLink.StartPointY, comLink.StartPointZ))
                             select sp).First();
                var end = (from sp in section.SectionPoints
                           where sp.Location.IsEqualTo(new Point3d(comLink.EndPointX, comLink.EndPointY, comLink.EndPointZ))
                           select sp).First();
                if (start != null && end != null)
                    yield return new Section.SectionLink(start, end, i, comLink.Type);
        public static IEnumerable<Section.SectionLink> GetValidSectionLinks(this CivDb.Section section)
            return (from sl in section.GetSectionLinks()
                    where sl.Type != SectionLinkType.NoDraw
                    select sl);
    public static partial class Section
        public class SectionLink
            public SectionPoint StartPoint;
            public SectionPoint EndPoint;
            public readonly int Index;
            public readonly SectionLinkType Type;
            public SectionLink(SectionPoint startPoint, SectionPoint endPoint, int index, SectionLinkType type)
                StartPoint = startPoint;
                EndPoint = endPoint;
                Index = index;
                Type = type;
    public enum SectionLinkType
        None = 0, // aeccSectionLinkNone
        NoDraw = 1, // aeccSectionLinkNoDraw
        All = 2 // aeccSectionLinkAll
Message 25 of 26
e_omairquliey
in reply to: hosneyalaa
Wow that is code to solve it. really amazing.
Where i can paste this code in lisp or visualbasic?
Message 26 of 26
hosneyalaa
Rail Community
